Go to Post resist the hive: As goofy as this may sound, wires do take up weight, several pounds of it. - Rickertsen2 [more]
Unread 17-02-2011, 18:02
jackdawg's Avatar
jackdawg jackdawg is offline
AKA: Wyatt Cerilli
FRC #1307
jackdawg is an unknown quantity at this point
watchdog
is watchdog completely necessary in this years code??
i ask because it seems to cause a fair amount of lag when when we add it in and it seems to be absent in the default code.
thanks
-Wyatt C FIRST Team 1307
Unread 17-02-2011, 18:09
2611.Shooter 2611.Shooter is offline
Programmer
AKA: Andrew Lavery
FRC #2611 (Vectors)
2611.Shooter is infamous around these parts2611.Shooter is infamous around these parts
Re: watchdog
whether or not it is required, it is a very good thing to have active in your code. without a watchdog, if your robot looses coms for even a second, it can really, really hurt itself. or get you a red card. however, though a very bad idea, i do believe that the watchdog is not required.
Unread 17-02-2011, 18:18
smcmahon's Avatar
smcmahon smcmahon is offline
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
smcmahon is an unknown quantity at this point
Question Re: watchdog
We were just talking about this as well.. We were getting a "watchdog not fed" error in auton testing, but couldn't find the thing ANYWHERE in the default code that we modified.
Where should it go? In which loop/VI?
FRC 2656 | FTC 5526 | VEX 9656
Unread 17-02-2011, 18:22
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
Re: watchdog
Watchdog isn't required but is highly recomended. The last thing you need is for your robot that your spent 6 weeks building to go haywire and get you a red card.
Unread 17-02-2011, 18:55
jackdawg's Avatar
AKA: Wyatt Cerilli
FRC #1307
Re: watchdog
ok. so if i add it where is it required???
which VI's??
thanks so much so far
Unread 17-02-2011, 21:54
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: watchdog
which VI's??
i don't have LabVIEW on this computer, but you should open the watchdog in begin and set its refnum. Then, it the autonomous and teleop while loops, make sure you include the Watchdog Feed VI (I don't remember which palate it's in off the top of my head)
Unread 17-02-2011, 22:51
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Re: watchdog
Watchdog is automatically implemented in the drive motors, and I'm pretty sure it's in the normal motors also. There's no reason to have another watchdog.
If you want to enable/disable it (it comes enabled) or change the timeout (it starts at .1 seconds), open up the drive motor open vi (in begin) and change the enum from enable to disable, or .1 to .2 or something.
If you want to make sure the watchdog is watching, get a freespinning motor or put the robot up on blocks, run it full power, and pull out the Ethernet cord. It should stop nearly immediately.
