Go to Post WHAT!?!?!? YOU DON'T DEVOTE YOUR LIFE TO APPLE!?!?!?!? ;) :p - Joe Matt [more]
Unread 17-02-2011, 22:29
qpang qpang is offline
qpang is an unknown quantity at this point
Need help - pwm
We are having a problem with pwm - the dashboard shows that pwm ports (on slot 4) has output while the joystick are moving, but jaguar lights keep yellow, and motor does not work as a result.
Any suggestion on troubleshooting?
Unread 17-02-2011, 23:00
Taylor Hawkins Taylor Hawkins is offline
2386 BCHS Trojans
FRC #2386 (Trojans)
Taylor Hawkins is an unknown quantity at this point
Re: Need help - pwm
2 Ideas
1) Check to make sure that the pwm cables are plugged in the correct way, there easy to get backwards.
2) Try replacing the pwn cables. I know that last year at a regional one of our motors wasn't working and replacing the cable fixed the problem
Hope this helps.
Unread 17-02-2011, 23:47
Re: Need help - pwm
All status lights on the Digital sidecar are a bright and glowing green?
The Dashboard shows you what your code is ordering, but nothing downstream from that point.
Unread 17-02-2011, 23:51
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Re: Need help - pwm
is the motor blinking yellow or is it solid yellow?
blinking= loss of connection
solid = good
