Go to Post Actually there are several Wayne Cokeleys circulating around. We cloned him in 2001. This is his evil twin Mordechai responding.....-WC 3 - Wayne C. [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 17-02-2011, 00:28
[TBT] Phoenix [TBT] Phoenix is offline
AKA: Blondie
FRC #2865 (Roboteknix)
[TBT] Phoenix is an unknown quantity at this point
2CAN Setup Help
After an immense amount of googling and searching, we were unable to figure out how to correctly setup the 2CAN module. We have read and re-read the PDF but we are still sitting here with a strobing orange light. Any help would be great!
Unread 17-02-2011, 16:55
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: 2CAN Setup Help
Some additional information would be helpful.
- 2CAN firmware version number.
- Are you able to connect to the 2CAN webdash?
- What is the IP of the 2CAN?
You can use the firmware utility to determine the IP of the 2CAN. If you are able to view the webdash do your Jaguars show up in the main page? An orange led indicates that the 2CAN is not communicating with the cRIO but has good CAN connectivity. This assume that you have the latest 2CAN firmware installed.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 17-02-2011, 18:54
BrandonG's Avatar
BrandonG BrandonG is offline
IRC Junkie
BrandonG is a glorious beacon of lightBrandonG is a glorious beacon of lightBrandonG is a glorious beacon of lightBrandonG is a glorious beacon of lightBrandonG is a glorious beacon of light
Re: 2CAN Setup Help
2CAN FW: 2CAN_Firmware_2_1_FIRST.crf
Can only connect to the web management page if it goes bridge====2CAN===cRIO1. Having it on port 2 of the cRIO will not let me see it.
IP is correct now at 10.28.65.10.
Not sure why it isn't seeing the cRIO, but I cant find anything anywhere (including CD) for example code or labview vi's for it. Ive spent about 4 hours googling and an hour searching here and have yet to find anything.
www.roboteknix.com
Originally Posted by A bum in Atlanta
if you was my sister I'd mug you
If anyone uses IRC, pm me and let me know what networks, I have never heard of anyone in FRC using IRC besides me O_o
Unread 17-02-2011, 23:00
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: 2CAN Setup Help
2CAN and the Black Jaguar CAN both use the same VIs.
The only difference is the plugin, which is set via the cRIO Re-imaging utility.
If you would like examples in LabVIEW, I can help you with that.
You can find my team's code here:
https://github.com/kamocat/ThunderTech_3213
If you'd like something specific, I can make an example.
-- Marshal Horn
