Go to Post Don't rely on the field staff to get every ball to work with your machine....engineer a robot that makes the change not matter. - PayneTrain [more]
Unread 17-02-2011, 20:22
3553's Dragonfly Signs of Life
It lives.
Unread 17-02-2011, 20:23
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: 3553's Dragonfly Signs of Life
I am jealous
Unread 17-02-2011, 20:27
Originally Posted by davidthefat View Post
I am jealous
Oh whoops it wasn't supposed to link to that logo. It is linked to the correct video now.
Unread 17-02-2011, 20:28
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Still, I am jealous
Unread 17-02-2011, 20:38
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
My team can pretend our arm is a cannon. Satisfied here for "coolness" of the robot.
Unread 17-02-2011, 22:18
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
You will probably want to switch out the outer extension tires to either plaction wheels or pneumatic tires. With only slick wheels on the extensions your robot will act like a giant lever when another robot pushes on it. It will actually make it easier to push/turn you rather than harder.
I don't know exactly how your design works but when your extensions come out are they picking the inner "driving" wheels off the ground? It appears that they are not in which case the above will pretty much be the case no matter what wheels you use.
Really cool design, it has great potential to be "that" robot this year once you work out the tricky spots.
Good Luck!
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 17-02-2011, 23:07
There are no slick wheels anywhere on the robot. The extension wheels are 8" plactions with wedgetop tread.
We are not lifted up when the wings come down.
Unread 17-02-2011, 23:29
BJC's Avatar
BJC BJC is offline
AKA: Bryan Culver
That's good. In your video the visable extension looked like it had slick KoP wheel on it. Upon closer inspection after the extensions moved up, however, I see it now. White treads are pretty sweet.
If I may ask one more question. When your extensions are down, where are your outer wheels in relation to the inner? ie. Slightly raised, in line, etc?
Thanks and best of luck, Bryan
Unread 17-02-2011, 23:36
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Dramatically slow wing raising.
So cool.
-Dustin Benedict
Unread 17-02-2011, 23:39
They are in-line with the inner wheels. The treads are just the normal beige wedgetop. The inner wheels have the roughtop.
Unread 18-02-2011, 01:33
So cool.
Hopefully that won't be the final speed. I'll get video this weekend hopefully of our First Flight
Unread 18-02-2011, 03:10
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Congratulations Akosh and team 3553. It's going to be fun keeping an eye on your robot this year ;>
The views expressed are mine and should not be construed to represent the views of anyone else.
