Go to Post I love the dedication of Robotics kids. :) - Danielle H [more]
  #31   Spotlight this post!
Unread 17-02-2011, 21:39
doot doot
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Re: Arm goes down too fast?
Originally Posted by pfreivald View Post
I'm not going to tell you everything...
Go play. Have fun with the idea. See if you can learn something, and drag some other kids along with you!
We played with it and boy are we happy now.
Other then some bouncing from other factors were working on, its now wonderful.
Will look for surgical tubing, because our balance point is pretty much about 6" above the floor with the bungee cords.
Thanks for everything guys!
  #32   Spotlight this post!
Unread 17-02-2011, 22:30
pfreivald's Avatar
AKA: Patrick Freivald
Happy to help. New video?
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #33   Spotlight this post!
Unread 17-02-2011, 22:33
doot doot
AKA: Brandon Liatys
Soon, its still bouncy but we know why we just didn't get to fix it yet. So the video will look similar to the last one. I'm waiting for our camera guy to send it to me
This helped alot though. Were getting surgical tubing tomorrow. How would you suggest tying it?
  #34   Spotlight this post!
Unread 17-02-2011, 22:34
pfreivald's Avatar
In knots...
Team 1551
I write books, too!
  #35   Spotlight this post!
Unread 17-02-2011, 22:48
doot doot
AKA: Brandon Liatys
In knots...
Oh, I thought there was some fancy way. I thought that if you did that, when you tension it the knots will just slip through whatever its tied to..oh well I'll have to try it tomorrow.
  #36   Spotlight this post!
Unread 18-02-2011, 00:19
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We tie it in a knot. Take the two ends, hold them next to each other, ends pointed the same direction, and tie a single normal overhand knot with both ends at once. That makes a loop. Then anchor the loop at both ends over something round, such as a 1/2" od nylon spacer with a 1/4" bolt thru it holding it to the robot or arm or whatever that end needs to attach to. If you make the anchor end adjustable, then you can adjust the tension as needed.
for example
  #37   Spotlight this post!
Unread 19-02-2011, 00:13
doot doot
AKA: Brandon Liatys
We found a spring, about 1" in diameter and about 6" long. When we stuck that on and gave the cables slack, the arm floated almost exactly horizontal. That works, then!
