Go to Post It doesn't matter if you write a thousand lines of code for a robot, if you didn't teach and/or inspire the HS students as you did it then you are not a mentor. - JamesBrown [more]
  #31   Spotlight this post!
Unread 14-02-2011, 17:16
Re: First team with swerve drive?
Now that you have reopened this discussion, I can enter what I forget to add before. Wildstang has always referred to this drive system as "crab" as that is the term camera dollies use. King Crab is a good choice for infinite rotation.
COTS Slip Rings are legal this year under <R40>.
  #32   Spotlight this post!
Unread 18-02-2011, 00:28
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
2783 EOT made a "unicorn drive" in 2009.
it had 4 pods. each had 1 cim coaxially driven (by way of a thin gates belt) and next to the cim was a globe for steering (also connected by a gates belt). each pod had 2 rover wheels, for a total of 8 wheels. steering position was determined by 4 analog encoders. no dead zones.
by definition and posted examples, this might have been the first "unicorn drive"
not bad for a rookie bot?
i do not have much in the way of good pictures. I can get some good ones tomorrow (it is still used as a demo bot).
I do have a couple from the Mt. Washington FLL regional (tickets were raffled for chances to drive it). They are attached.
Upon my move to the team, i was shocked that they built it as rookies. I surely thought that it had been done by a veteran team earlier (coxiaxial 4 wheel independ. swerve), but according to this thread this may have been the first. go figure.
ID:	10190  Click image for larger version
  #33   Spotlight this post!
Unread 18-02-2011, 00:44
Originally Posted by ratdude747 View Post
2783 EOT made a "king crab" in 2009.
it had 4 pods. each had 1 cim coaxially driven (by way of a thin gates belt) and next to the cim was a globe for steering (also connected by a gates belt). each pod had 2 rover wheels, for a total of 8 wheels. steering position was determined by analog encoders
Was it programmed to be holonomic (all three degrees of freedom independently and simultaneously controllable) ?
  #34   Spotlight this post!
Unread 18-02-2011, 01:17
ratdude747's Avatar
AKA: Larry Bolan
if what you mean is arcade drive (one stick does f/b and l/r, the other controls rotation), then yes.
if not, it wasn't, but the programmer is good enough that he could have if he wanted to. hardware wise, it is the "unicorn drive".
  #35   Spotlight this post!
Unread 18-02-2011, 01:58
Yes, it sounds like Unicorn. You mentioned that the steering angle sensors were analog encoders. Do you remember what the make and model number was?
Also, did your team ever post any technical information about the control algorithms?
  #36   Spotlight this post!
Unread 18-02-2011, 02:17
spacepenguine spacepenguine is offline
AKA: Ian Hartwig
spacepenguine is an unknown quantity at this point
We certainly weren't the first, but 226 had a "unicorn" drive last year. I believe it was a belt driven coaxial system.
2008-2011: #226 - The Hammerheads
  #37   Spotlight this post!
Unread 18-02-2011, 02:19
ratdude747's Avatar
AKA: Larry Bolan
as far as i know no data was published. the signifigance of the bot was never really noted on the team.
they do have solidworks archives of the pod modules... and the engineering mentor who donated the use of his shop has a spare pod to it...
they do not know how special the bot is. they will tomorrow. Actually, the code for it may be lost... we are looking for a copy so we can convert it to CAN bus (yes, it is jaguar based. all 10 of them.)
the encoders are US digital analog encoders, model MA3-A10-125-B. they have a 1/8" shaft, with ball bearings. the cables are hand braided to reduce noise.
the nice thing is to make it fit on the shelf for storage, the top part of the bot is off, giving a nice view of the drivetrain.
  #38   Spotlight this post!
Unread 18-02-2011, 03:16
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Independently steered? How many Globe motors?
  #39   Spotlight this post!
Unread 18-02-2011, 06:59
ratdude747's Avatar
AKA: Larry Bolan
4 globe motors.
  #40   Spotlight this post!
Unread 18-02-2011, 07:04
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
4 globe motors.
That makes the fact that it passed inspection the strangest part of all. Only 2 Globes were legal to use in 2009.
  #41   Spotlight this post!
Unread 18-02-2011, 07:21
ratdude747's Avatar
AKA: Larry Bolan
funny... 1024 used 4 globes for their crab that year.
  #42   Spotlight this post!
Unread 18-02-2011, 07:26
Allison Allison is offline
AKA: Allison Phelps
FRC #1024 (Kil-A-Bytes)
Allison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant future
1024's crab drive in 2009
The front wheels were steered independently and the back wheels were linked.
2 Globe motors (front steering)
1 Window motor (back steering)
2 Fisher Price (drive)
Hope this clears things up
Allison
  #43   Spotlight this post!
Unread 18-02-2011, 07:57
aechmtwash11 aechmtwash11 is offline
FRC #2783
aechmtwash11 is an unknown quantity at this point
As Larry said,
in 2009 we (2783) used a unicorn drive. Here is a run down of the specs:
4 CIMs
2 Globe
2 Fisher Price w/globe gearbox
8 rover wheels
4 analogue absolute encoder
8 Gates Belts
9 Jags
Originally we did have the code & CAD published but in got lost in the many revisions to the website. Also, being rookies our organization skills weren't that great so we are looking for the FINAL code we made right now so we can covert the drive system over to CAN.
I am looking in our picture archive on our web server for some pics right now. Will post if I find them.
  #44   Spotlight this post!
Unread 18-02-2011, 08:18
FRC #2783
Here are some pics of our 2009 crab drive named "Mac"
www.kyeot.com/photoViewer.php
NOTE: These pics were not orginally taken to show off the modules. We took them because we had to make some frame modifications between boilermaker and the Championship in Atlanta
2783, Engineers of Tomorrow
  #45   Spotlight this post!
Unread 18-02-2011, 08:25
ratdude747's Avatar
AKA: Larry Bolan
thanks Austin... I though i saw a couple FP's down there... yay, the school filter hasn't blocked CD YET.
sorry for getting 1024's drive wrong... i rembered 4 motors... obviously i remembered wrong!
pic: Team 2220's Swerve Drive Chasis Jedward45 Extra Discussion 21 11-01-2011 16:00
Team 2338 swerve drive peer review Creator Mat Technical Discussion 13 17-06-2009 17:45
Swerve Drive with new wheels Carl Green General Forum 0 04-01-2009 18:22
pic: Team 108 - LEGO swerve drive zander_108 Extra Discussion 8 10-04-2007 22:36
pic: My first Lego Swerve Drive Ken Leung Extra Discussion 5 16-08-2006 23:56
