Go to Post FIRST is supposed to be a learning experience. Learn first, win awards later. - evulish [more]
Unread 15-02-2011, 20:38
Liu_yiang Liu_yiang is offline
AKA: Ian Pai
FRC #1245 (Shazbots)
Team Role: Electrical
Liu_yiang is an unknown quantity at this point
Shortening Light Sensor Wires
Hey, does anyone know of a way to strip the black insulation off the light sensor? We need to shorten them down A LOT, but the last time I tried to lengthen the wires I almost sliced the blue and white ones off.
Tips? Tricks?
Unread 15-02-2011, 21:01
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Tips? Tricks?
I've had decent luck with using a knife to score a complete circle 3 or 4 times around, not actually cutting all the way through, and the firmly twisting the insulation you want to remove, it usually tears neatly along the score, and can be slipped off.
I've only done this with 6" lengths, it tends to get harder with longer bits to remove, but you could repeat the procedure a few times as necessary.
Matt
Matt Krass
Unread 16-02-2011, 15:55
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Re: "
I traditionally do the same thing, only I:
1. Score (shallowly) a complete circle around the shielding.
2. Bend the wire (about 90 degrees), causing the shielding to separate where it has been scored.
3. Push a blade down SLOWLY (never "slice") into the separation until the shielding breaks apart - usually it will break apart without you having to go all the way through with your blade.
4. Bend the wire in another direction, and repeat - until the shielding has broken all the way around.
This is what I do for really large wires (that I have to manually strip) when I don't want to cut into the wire underneath, or extremely tiny wires where I'm afraid I'll cut all the way through.
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 16-02-2011, 16:03
JDL JDL is offline
Systems Integrator
FRC #0498
JDL is just really niceJDL is just really niceJDL is just really niceJDL is just really nice
Re: Shortening Light Sensor Wires
Really you should be using a cable slitter, or a hook blade lineman's knife for safety but a utility knife will work. Just score the jacket all the way around and twist and pull it off.
It can be done with a pair of lineman's pliers or dykes too but unless you're good at doing it that way it's real easy to screw up the conductors inside.
Unread 17-02-2011, 09:09
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
One of my mentor just took a razor blade and slice straight down, slowly. I don't know why he did that, but our sensors are working fine.
Unread 18-02-2011, 01:22
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
i wonder if a plumber's tubing cutter (wheel type) would work? i will have to try one tomorrow.
Unread 18-02-2011, 08:07
I wouldn't recommend a tubing cutter, it works for coax but not for more fragile wire. If you take a sharp knife or a razor blade, bend the wire in half, and gently rock the blade over the outside jacket until the inner wire becomes visible. Rotate the wire and repeat until you have opened the jacket all the way around. Now gently grab the wire with a hand on both sides of the open jacket and pull while sliding one hand towards the end of the cable. If you repeat this operation, the entire outer jacket can be removed.
However, I highly recommend that you leave as much wire on the sensor as possible so that when you use it next year on a different robot you have enough length to install it. Simply coil the excess cable into a tight coil and tywrap it in place, out of the way.
Unread 18-02-2011, 10:01
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
More sage advice from Big Al. I was going to have my electrical team trim them back but now, no. Thanks
Unread 18-02-2011, 10:10
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
Excellent advice as always. Even if they don't put lines on the field next year these devices should work well as a "break beam" type sensor or optical limit/position switch when paired with a bit of reflective material. I believe that is actually the "intended" purpose of these devices.
