Go to Post There is something to be learned (sometimes hard to find) from everyone you meet. - wireties [more]
Unread 18-02-2011, 10:51
pigpc1993 pigpc1993 is offline
AKA: Colin Feeney
FRC #3716 (WARP)
pigpc1993 is an unknown quantity at this point
Joysticks
We are having issues with our code on programming the joysticks. When we press the button our solenoids switch but sometimes they will switch right back. The Dashboard shows that they switch and then switch back sometimes. So I know they are opening. Any suggestions. Here is the code we are using
            if(js2.getRawButton(3) == true && j2b3 == false){
                s1.changeSolenoid(a1, a1End);
                s2.changeSolenoid(a2, a2End);
                j2b2 = true;
            else{
                j2b2 = false;
Unread 18-02-2011, 11:27
mobilegamer999 mobilegamer999 is offline
FRC #3357 (Comets)
mobilegamer999 is a jewel in the roughmobilegamer999 is a jewel in the roughmobilegamer999 is a jewel in the rough
Re: Joysticks
should it be j2b2 in the primary if statement as opposed to j2b3? not sure if that was a typo in posting, if so, then I might need a little bit more detail to help you.
Unread 18-02-2011, 12:02
Electrical Engineer
Rookie Year: 1995
Re: Joysticks
                j2b2 = true;
            else{
                j2b2 = false;
What you are experiencing is called "contact bounce". From Wikipedia:
Contact bounce (also called chatter) is a common problem with mechanical switches and relays. Switch and relay contacts are usually made of springy metals that are forced into contact by an actuator. When the contacts strike together, their momentum and elasticity act together to cause bounce. The result is a rapidly pulsed electric current instead of a clean transition from zero to full current. The effect is usually unimportant in power circuits, but causes problems in some analogue and logic circuits that respond fast enough to misinterpret the on-off pulses as a data stream.
You have to implement a filter function commonly called a switch "debounce" to get rid of the problem.
Mike Betts
As easy as 355/113...
Unread 18-02-2011, 12:06
AKA: Colin Feeney
FRC #3716 (WARP)
Re: Joysticks
How might a fix this?
Unread 18-02-2011, 12:26
Electrical Engineer
Rookie Year: 1995
Re: Joysticks
I would start by searching for the word debounce... You may find something.
Mike Betts
Unread 18-02-2011, 18:12
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
Re: Joysticks
One thing you can try is editing your else to an else if:
} else if (js2.getRawButton(3) == false) {
This makes sure it only reverts to true when the button is released.
while(!going.isTough());
tough.exit();
What will we do tonight, Warfa?
The same thing we do every night, Patrick. Sit and wait for Electrical.
Unread 19-02-2011, 21:58
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Re: Joysticks
The easiest way to implement debounce is to have a counter where you have to read an input for a certain number of times for it to be considered valid.
Brian K
Team 1225 Robotics Mentor
