Go to Post Screws come even smaller, #0000 - 160 at Small Parts.They're about $4 each, and made by elves. - DonRotolo [more]
  #46   Spotlight this post!
Unread 18-02-2011, 10:52
Re: Banebots RS-775 Case Short
OK,
Now I am really confused. I haven't taken a 775 apart. I wonder if there is winding terminations at both ends of the armature.
  #47   Spotlight this post!
Unread 18-02-2011, 12:24
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
For what it's worth, 3 of our 8 775s had a short to case. I had marked them as "bad" and was going to pitch them in the trash. After reading here about the zaping procedure I figured what the heck and gave it a try. The zaping procedure seemed to fix all three of our motors, however, we will still not be using them in competition and are considering not using any 775s at all and changing our plan to use 550s and the FP. I am pretty disappointed in BaneBots over the years and this just adds insult to injury.
Of the 3:
The first 2 sparked somewhat spectacularly both apparently from the larger holes near the back/terminal end.
The last 1 produced almost no spark at all and was only visable as a tiny (~1/16") arc when the wire touched the case. No sparks apparent coming from inside the motor.
The first one we zapped with the lights on and sparks were clearly visable even in a well lit area. For "effect" we cut the lights off on the last 2 and the first one sparked nicely and the last one was the one with almost no spark which probably wouldn't have even been visable if the lights were on. On all three it only took one zap to fix the motor. The procedure was about as simple as it gets. I took a robot battery plugged in an Anderson connector with bare wires, held the red to the red terminal on the motor and touched the black to the case. No breaker involved. For as strange of a "recomended fix" as this is it seemed to work. The second motor we did does have a slight burned black line on the case where the wire touched. Other than that no other obvious signs on the outside other than where I wrote on them with a Sharpie.
  #48   Spotlight this post!
Unread 18-02-2011, 12:31
You left out the most important step:
I checked to make sure everyone in the room was wearing their safety glasses.
  #49   Spotlight this post!
Unread 18-02-2011, 14:28
Yeah, and we made sure there were no flamable liquids ar vapors nearby as well.
  #50   Spotlight this post!
Unread 18-02-2011, 15:22
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I'm super curious as to what exactly is shorted in the first place, and is blowing apart inside during this procedure. Can someone who has some 775 spares sacrafice one for curiosity's sake?
  #51   Spotlight this post!
Unread 18-02-2011, 16:41
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
2 of our 6 RS-775s had case shorts as well. We tried the case-to-lead zapping procedure recommended by BaneBots, and it remedied the problem on both. We did have to zap one of them twice after we spun it a few times after the first attempt. I wish there was a safer way to fix this without taking them apart.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
  #52   Spotlight this post!
Unread 18-02-2011, 16:49
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I keep forgetting to measure ours, we just have the one that came in the kit. If it's shorted, I'll take it apart. If I remember. We happen to be kind of busy building a robot, so I'm sort of distracted when I'm at the school.
  #53   Spotlight this post!
Unread 18-02-2011, 16:52
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
We just two more yesterday and checked them. They are both good! We have to earlier and they are good two.. I guess we got lucky
Faridodin "Fredi" Lajvardi KD7WKD
  #54   Spotlight this post!
Unread 18-02-2011, 22:38
Chris is me's Avatar
AKA: Pinecone
Our kit motor and one of the three we ordered had the case short. Luckily the decision was made to use a Window motor on our arm instead. The other two motors were installed on CIMulators and will be put on our drivetrain once we find some CIM keys...
I'm really hesitant to do the battery pulse fix on these motors. We'll see.
  #55   Spotlight this post!
Unread 19-02-2011, 09:48
Hey Jim, You have used that excuse in the past.
  #56   Spotlight this post!
Unread 19-02-2011, 10:13
MrForbes's Avatar
AKA: Jim
Thanks for reminding me to make a reminder for myself....hopefully I'll see it when I write some other reminder on my hand today.
  #57   Spotlight this post!
Unread 19-02-2011, 10:18
Ah, the signs of spring are in the air, preship craziness. I am off to playing field and shop for a day of fun and fluorescent light.
  #58   Spotlight this post!
Unread 19-02-2011, 12:49
MrForbes's Avatar
AKA: Jim
We got lucky, our kit 775 has less than two ohms resistance between the case and terminals. Good thing we didn't try to use it. We did not try to clear the debris with the battery trick, but did take it apart, and aside from slightly chipping the brushes while removing the end cap, did not see any debris. The windings are almost a dead short to the motor shaft (measured between shaft and commutator). Any suggestions for what to do now? Maybe we could unwind the windings? the soldering job doesn't look very good, but it also doesn't look like it would be causing problems. I took some pics but don't have means to get the pics off my camera here at school.
  #59   Spotlight this post!
Unread 19-02-2011, 18:48
sandiegodan's Avatar
sandiegodan sandiegodan is offline
FTC Mentor, FRC Inspector
AKA: Dan Glenn
FTC #10092 (Green.Griffins;)
sandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to all
I pulled our Banebot 775 apart before I read about the fix. The connection to the case is through the rotor assembly to the rotor shaft. A direct short can be read between the commutator and the shaft.
There is no obvious debris. I could speculate what happens during the "manufacturing process," but until Banebots is more forthcoming with specifics, I don't think we will really know. The rotor assembly is pressed then varnished, without extensive forensics, I would say the exact problem will be hard to get at. There are some balance holes machined out of the stack, so maybe that is the source of the issue.
After I reassembled, I applied the battery current across the terminal and case. There was a minor spark and now the motor is fine. We can't use it in competition since it has been disassembled, but it will be perfectly acceptable for practice.
If anyone knows if Banebots is replacing these it would be nice to know.
Dan Glenn
Team 1622 Spyder, Poway High School, California
Dan Glenn
2015-16 FRC Chairman, San Diego Regional Planning Committee
2016 FRC Inspector, Orange County (LRI), Los Angeles, Carson Division
2015 FRC Inspector, Inland Empire (LRI), Central Valley, Los Angeles, Galileo Division
2015 FTC Mentor 10092 Green.Griffins; R&D Robotics Education
2014 FRC Inspector, Inland Empire, San Diego(LRI), Archimedes Division
2012-15 FTC Mentor Team 6565 Stuffed Dragons & 8489 Green Griffins Boys and Girls Club
2013 FRC Inspector, Central Valley, San Diego(LRI), Los Angeles, Inland Empire, Galileo Division
2012 FRC Inspector, San Diego, Los Angeles, Central Valley, Newton Division
2009-12 FRC Mentor Team 1622 Spyder Poway HS
2007-08 FRC Mentor Team 2658 Pedestrian Rancho Bernardo HS
  #60   Spotlight this post!
Unread 19-02-2011, 20:14
MrForbes's Avatar
AKA: Jim
picture of armature.
