Go to Post There is nothing wrong with being great and being proud of it. - TubaMorg [more]
Unread 18-02-2011, 12:42
bensherman's Avatar
bensherman bensherman is offline
AKA: Ben Sherman
FRC #1676 (The Pascack Pi-oneers)
Team Role: Electrical
bensherman is a glorious beacon of lightbensherman is a glorious beacon of lightbensherman is a glorious beacon of lightbensherman is a glorious beacon of lightbensherman is a glorious beacon of light
Re: is my wiring good?
I recommend using a switch that locks in the open position when the bot hits the top. In our testing, limit switches on the top that didn't lock cause issues when taking the bot down. As soon as it starts to slide down, the switch is back in the initial position and will climb the pole again, then repeat. You can make an apparatus to keep the switch in the NO position when it hits, but a push button type of switch is the easiest and (should be) the most reliable.
2011 NJ Regional #1 seed, winner
2011 Virginia Regional winner
2010 New Jersey Regional Winner
2010 Virginia Regional Winner (15-0 )
2010 Curie Finalists
Editor - alltechdaily.com
