Go to Post Wow, my dad's sadistic nature is rubbing off on me. - Lil' Lavery [more]
Unread 18-02-2011, 13:22
Team 2524 Team 2524 is offline
FRC #2524
Team 2524 is an unknown quantity at this point
Using Vex Sensors Line Tracking Kit instead of sensors provided
My mentor ordered the vex sensors line tracking kit because the sensors we had weren't working and is it possible to program these sensors in labview for FRC?
And is it possible to connect it to DSC?
Vex Sensor Encoder Kit #276-2156
Light Sensor Kit
Optical Shaft Encoder Kit
Ultra Range Finder kit
Potentiometer
Sensors Line TRacker Kit-Containing 3 sensors
1 mounting bar
Unread 18-02-2011, 13:36
Re: Using Vex Sensors Line Tracking Kit instead of sensors provided
Did you read the information on the Vex wiki? http://www.vexforum.com/wiki/index.php/Line_Follower
Hint: They don't attach to the digital sidecar.
Unread 18-02-2011, 15:15
FRC #2524
Okay, but is it possible to substitute the Allen Bradley sensors for the vex sensors and still be able to use labview?...
We still haven't opened up the package yet because we don't want to take that chance that it doesn't work and regret it.
Does anyone have any experience using vex parts?
Unread 24-02-2011, 20:49
scienceguy22 scienceguy22 is offline
FRC #3641 (The Flying Toasters)
scienceguy22 is an unknown quantity at this point
The vex line followers work on a different concept the the KOP sensors. The supplied sensors are your basic yes/no, is it, or is it not on the line. Vex sensors measure the intensity of infared light that reflects off of the surface being measured; the vex sensors return integer values based on the intensity, there's a data sheet that comes with them that explains it more in depth. The major difference in using them would be using the analog breakout rather than the digital sidecar along with using comparisons and then going to a true/false case structure, rather than going directly to a true/false case structure, in programming.
Unread 24-02-2011, 21:59
Clayton Yocom's Avatar
Clayton Yocom Clayton Yocom is offline
Programming Mentor
FRC #0027 (RUSH)
Clayton Yocom will become famous soon enoughClayton Yocom will become famous soon enough
Send a message via AIM to Clayton Yocom Send a message via MSN to Clayton Yocom Send a message via Yahoo to Clayton Yocom
Originally Posted by Team 2524 View Post
Okay, but is it possible to substitute the Allen Bradley sensors for the vex sensors and still be able to use labview?...?
Yes, you can. The better question is, "Will the vex sensors work with the default autonomous code?", to which the answer is no. You'll have to do some changing of the code to get it to work, as they work, as ScienceGuy22 said, on in integer vs. boolean t/f.
I haven't looked at the default code at all, but my guess is that with a little bit of tinkering you can get it working (maybe even better ).
Unread 02-03-2011, 12:41
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
"The line tracker is an analog sensor, meaning that it can output many more values within its range of potential values (in this case, from 0-5V) than a digital sensor, which would output only a handful of discrete values in the range (e.g., 1, 2, 3, 4, and 5V), as is the case for a digital sensor. This range of output from 0-5V is sent to the microcontroller, which translates it into a corresponding range of integer values from 0-255."
Wow, a digital sensor that outputs discrete values based on voltage. That is a WEIRD way to put it.
