Camera dislikes cRIO
We are trying to set up a camera and are having a very strange issue. While the camera seems to work with older cRIOs (with the exact same code and image) it doesn't want to show anything with this years. All help would be appreciated.
Re: Camera dislikes cRIO
Are the case of the cRIO and camera shorted to the frame? They shouldn't be.
No they are not
The code has been confirmed to be correct, what is happening is when we plug the camera into the cRIO, both the green and yellow lights are solid and we think that the yellow light is supposed to be flashing
Hi,
I'm using the camera AXIS 206. My camera was runnig before I did the drive station and the 3.2 labview update. after this the camera didn't show in the dashboard(drive station). and when i passed the code to the robot, there are errors about the camera. can you help me? |
Is the camera reset switch being pressed accidentally?
#7
no, i didn't press the switch reset.
but if i pressed what i need to do? thank you! |
#8
#9
The reset button is not being pressed for us, but we have tried resetting it and it didn't work
