Go to Post "We're too close for missiles, switching to Poof balls!" "Just one more day on the driving code, then I'll switch to autonomous." - Rick TYler [more]
Unread 18-02-2011, 17:23
Re: Solenoids (What ones can be used?)
<R66-B> is your friend. (Also note <R66-C>.)
<R66> In addition to the items included in the KOP, pneumatic system items specifically permitted on 2011 FRC ROBOTS include the following items. All included items must be “off the shelf” COTSpneumatic devices rated by their manufacturers for working pressure of at least 125psi and used in their original, unaltered condition (except as required for assembly with other components).
B. Solenoid valves with a maximum ⅛” NPT port diameter, and a maximum Cv of 0.32 (if non-KOP valves are used, the team will be required to provide part documentation validating that the valves meet these constraints).
C. Solenoid valves that are rated for a maximum working pressure that is less than 125psi rating mandated above are permitted, however if employed, an additional pressure relief valve must be added to the low pressure side of the main regulator. The additional relief valve must be set to a lower pressure than the maximum pressure rating for the solenoid valve.
Instead of posting and waiting two hours for someone to see and respond, it may have been faster to read the Game Manual, Section 4.3.11, Pneumatic System.
Unread 21-02-2011, 10:04
purduephotog purduephotog is offline
Active Defense Design Engineer
AKA: Jason
FRC #3015
purduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the rough
Send a message via AIM to purduephotog
I believe he was looking for specific part numbers, as SMC's site is sometimes difficult to navigate.
That's what I read his question as.
http://purduephotog.deviantart.com
Portrait Photography: "I used to say Immortalized in Silver, but now I say Captured and Squeezed by Electrons".
Unread 21-02-2011, 10:19
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Eric has become our resident read-the-manual-troll. It has gotten to the point where I cringe when I see that he has responded to a post.
Unread 21-02-2011, 10:29
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
I don't think I would call Eric an RTM troll, I've met him and he is too tall to be a troll
But seriously, he does perform a valuable service and has a wealth of knowledge on the rules.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 21-02-2011, 10:55
IndySam's Avatar
I understand and respect his knowledge, but is this an appropriate response?
And that's one of his tame ones.
A better response would have been, here's the rule. And then here's some help.
Unread 21-02-2011, 12:51
I posted the rule, then commented that there was a faster way to get the legality information.
Now, legally, part numbers don't matter, specs do. Any solenoid that fits the specs given is legal. If the question had asked for part numbers, then I might not have answered (and almost certainly wouldn't have answered with the rule).
