Go to Post The difference between a Tinkerer and an Engineer is that the Engineer will be able to tell you the results before you start. - DonRotolo [more]
Unread 18-02-2011, 17:30
yogiyogi yogiyogi is offline
FRC #2679
yogiyogi is an unknown quantity at this point
autonomous help! - line tracking
hi everybody!
we are getting really hard time on line tracking...we are using 4 mecanum wheels that are controlled with 4 motors. we are trying to change the default code to wrok with no success.
can sombody please help? or even post some code? thank you very much
Unread 18-02-2011, 18:43
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: autonomous help! - line tracking
What language?
How many sensors are you using?
Unread 19-02-2011, 07:04
FRC #2679
LabView
3 photosensors
Unread 19-02-2011, 14:40
Originally Posted by yogiyogi View Post
hi everybody!
If you opened your drive motors using "4 motor drive", and mounted your photosensors as instructed, the default code should work as is, with perhaps some tweaking of the motor speed array.
