Go to Post Boy you guys try to make my job harder every year. - Al Skierkiewicz [more]
Unread 18-02-2011, 18:27
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Pneumatics not working
The valves will remain in whatever position they were in when you last used them. If that position is sending air to the cylinder port that extends the rod then that's what it will do when the compressor charges the system.
To get them to retract just push in the little button on top of the valve (by the connectors) that will cause the valve to change over to the other position. If you push one and nothing happens simply push the other one on the other end.
BTW there needs to be a little air in the system for this to work.
