Go to Post "I don't have a cockroach in my presentation.... " I will remember this line forever. Thank you Autodesk. - Zyik [more]
Unread 18-02-2011, 18:04
RoboElite640 RoboElite640 is offline
FRC #0640
RoboElite640 is an unknown quantity at this point
problem with motors and programs
When we run the robot, we have button 3 and button 2 on the right Joystick move the arm. but when we try it doesnt work. The speed controller turns red when we try, but w/o the codes its yellow. Anyhelp is our code wrong, cuz our tankdrive works
package org.team640;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Victor;
import edu.wpi.first.wpilibj.camera.AxisCamera;
import edu.wpi.first.wpilibj.camera.AxisCameraException;
import edu.wpi.first.wpilibj.image.ColorImage;
import edu.wpi.first.wpilibj.image.NIVisionException;
public class FRC2011Team640 extends SimpleRobot {
private final double TARGET_SCORE_THRESHOLD = .01;
private RobotDrive robotDrive = new RobotDrive(1,2);
private Victor arm = new Victor (3);
private Joystick stickLeft = new Joystick(1);
private Joystick stickRight = new Joystick(2);
private AxisCamera cam;
private TrackerDashboard trackerDashboard = new TrackerDashboard();
public FRC2011Team640() {
getWatchdog().setExpiration(0.5);
initializeTargetting();
public void autonomous() {
getWatchdog().setEnabled(false);
for (int i = 1; i <=4; i = i +1) {
robotDrive.drive(0.5,0.0);
Timer.delay(2.0);
robotDrive.drive(0.0,0.0);
Timer.delay (2.0);
private void processTarget() {
try {
System.out.println("Trying to obtain image");
if (cam.freshImage()) {// && turnController.onTarget()) {
System.out.println("Have fresh image");
ColorImage image = cam.getImage();
Thread.yield();
Target[] targets = Target.findCircularTargets(image);
Thread.yield();
image.free();
if (targets.length <= 100 || targets[10].m_score
< TARGET_SCORE_THRESHOLD) //length == 0 (original)
System.out.println("No target found");
Target[] newTargets = new Target[targets.length + 1];
newTargets[0] = new Target();
newTargets[0].m_majorRadius = 10;
// radius = 0 (original)
newTargets[0].m_minorRadius = 1;
newTargets[0].m_score = 2;
for (int i = 1; i < targets.length; i++) {
newTargets[i + 1] = targets[i];
trackerDashboard.updateVisionDashboard(0.0, 0.0,
0.0, 0.0, newTargets);
} else {
System.out.println("HAVE TARGET!!!!!");
System.out.println(targets[0]);
System.out.println("Target Angle: "
+ targets[0].getHorizontalAngle());
0.0, targets[0].m_xPos / targets[0].m_xMax, targets);
} else {
System.out.println("No image");
} catch (NIVisionException ex) {
ex.printStackTrace();
} catch (AxisCameraException ex) {
private void initializeTargetting() {
Timer.delay(10.0);
cam = AxisCamera.getInstance();
cam.writeResolution(AxisCamera.ResolutionT.k320x24 0);
cam.writeBrightness(0);
public void moveArm1() {
getWatchdog().feed();
arm.set(1.0);
Timer.delay(0.4);
public void moveArm2 () {
getWatchdog().setEnabled(true);
arm.set(1.0);
Timer.delay(3.5);
public void operatorControl() {
while (isEnabled() && isOperatorControl()) {
if(stickLeft.getRawButton(3))
{ moveArm1();}
else if (stickLeft.getRawButton(2))
{ moveArm2(); }
Unread 18-02-2011, 18:24
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
Re: problem with motors and programs
Does your driver station report the watchdog being fed? I don't know much about the SimpleRobot template, but in Iterative a delay like the ones you have in your moveArm functions would starve the watchdog until the delay is over.
while(!going.isTough());
tough.exit();
What will we do tonight, Warfa?
The same thing we do every night, Patrick. Sit and wait for Electrical.
Unread 18-02-2011, 19:49
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
Take a look at your operatorControl.
You should have
under
while(isEnabled && isOperatorControl()) {
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 18-02-2011, 21:34
FRC #0640
yeah, we changed it so that the watchdog is fed, but it still doesnt move the motors. could it be wiring problem because when we try to move the arm in driverstation, the speed controlers turn red or is that because our code is bad?
Unread 18-02-2011, 21:41
What do they do when they turn red? Is it solid, quick flashing, or slow flashing? Based on your code, they should be either solid red or solid green (running at 100%). In any case, it may be worth checking the wiring.
tough.exit();
Unread 18-02-2011, 21:52
FRC #0640
Its solid red. We have the wire going to port 3 for the motor in the digital sidecar.
Unread 18-02-2011, 22:17
My apologies: I didn't notice that you were using Victors and not Jaguars - I do not believe the solid red/blinking red diagnostic tool exists on the Victors. However, if the watchdog is reportedly fed, I would still go at it with a multimeter to see if it is receiving a signal.
tough.exit();
Unread 19-02-2011, 10:55
With Victor motors, they do indeed give out light for diagnostics. Just the same as Jaguars, actually.
Blinking orange - No input
Red - backwards
Green - forwards
If you have your dashboard coded (you can just use the sample if you haven't already), you can actually get a feed from PWM channels 1-10, typically under Slot 4. If your light is red, the dashboard should show whatever channel you have your victor plugged in to as a meter going down.
[Robots R Us #3266]
2011: Buckeye
2010: Buckeye
