Go to Post It would be better as the software person to preach to your team early on for non-reliance on software. - Tom Bottiglieri [more]
Unread 15-02-2011, 16:20
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
pic: Building blocks of a 1 lb shifting transmission
Unread 15-02-2011, 16:21
AdamHeard's Avatar
Lead Mentor
Re: pic: Building blocks of a 1 lb shifting transmission
I don't believe it. Not by the time the sprockets, bolts, spacers, etc... are all added in.
Although, I'm hopeful to see the final result!
Unread 15-02-2011, 16:37
nvm
Unread 15-02-2011, 16:48
nick_sheets nick_sheets is offline
FRC #3569
Team Role: CAD
nick_sheets will become famous soon enoughnick_sheets will become famous soon enough
Im confused, how is that even possible. The big gear is huge and 4 of those gears alone weigh a lb?
Am I wrong and why are they different colors? Aren't these just gears from AM?
Unread 15-02-2011, 16:51
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
You would have had to essentially remove a quarter of a pound, or a bit more, from the 2007 transmission 254/968 used to get to 1lb even. I don't see that as physically possible.
Did you hob your gears? Cut them with a form cutter? What alloy? Have you decided it wasn't worth the work yet? (Don't mean to be snarky-just that you can find numerous comments from 968/254 members that it absolutely was not worth the amount of effort it took to save 2 lbs).
2001-2004: Team 100
2006-Present: Team 254
Unread 15-02-2011, 17:42
team222badbrad's Avatar
Happy Birthday! team222badbrad team222badbrad is offline
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
For reference our 3d printed ABS plastic ball lock transmission (as shown here less CIM) is 26 ounces.
The only metal parts are two 1" bearings, three thrust bearings, air cylinder, a few bolts and a precision 1/4" shaft.
http://www.chiefdelphi.com/media/photos/36161
It is possible to make a 1 pound transmission, but will it hold up?
Are you direct driving a wheel?
What are you using to shift?
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 15-02-2011, 17:50
AKA: Sean
Ha wow leave it to CD to take everything literally. It will probably turn out closer to 1.5lbs per transmission. This was really just supposed to show off some cool gears that will save a decent amount of weight over their steel counterparts
They are 7068 aluminum hobbed and anodized. These should also hopefully be available for purchase by next season for anyone interested in saving a big chunk of weight and higher quality over andymark gears.
Cory, had we been investing our time into making these versus just machining steel gears we would have gone the steel route as well but given the choice to do both without any extra resource allocation we went with the aluminum. The only downfall was the wait (no pun intended) but that was remedied by running steal gears in the interim
Unread 15-02-2011, 19:48
poohbear poohbear is offline
FRC #3815
poohbear is on a distinguished road
Thumbs up Re: pic: Building blocks of a 1 lb shifting transmission
those look awesome! (This team is definitely gonna win Einstein guys. no doubt about it)
Unread 18-02-2011, 22:20
Borisdamole Borisdamole is offline
mercernary machinist
AKA: Taylor
FRC #0973 (most with 973)
Borisdamole is just really niceBorisdamole is just really niceBorisdamole is just really niceBorisdamole is just really niceBorisdamole is just really nice
Send a message via AIM to Borisdamole
so have you weighed the finished trans yet? I would love to see the final weight!
OUTWORK US
