Go to Post - Only think of Gracious Professionalism as a standard to work toward personally. - Never use it as a gauge to point out someone else’s shortcomings. - Rich Kressly [more]
Unread 18-02-2011, 17:46
UltimatJose's Avatar
UltimatJose UltimatJose is offline
Team 3080 Design Team/Build Team
AKA: Jose Ramirez
FRC #3080 (So-called Robotics)
Team Role: Driver
UltimatJose is an unknown quantity at this point
CRIO HELP NEEDED!
After many attempts of trying to send "Run as Start up" succesfully,to the CRio, we got a message that said it couldn't connect. I turned it off and tried it again, but it never caught it. I tried to reimage it to v28, since i had it on v25 but it would always get error 60?? after the reboot process. I reset the ip adress. now it's at 0.0.0.0 and now i can't reimage it at all. help?
Unread 18-02-2011, 21:10
Kyoshirin's Avatar
Kyoshirin Kyoshirin is offline
Renaissance Man
AKA: David
FRC #1188
Kyoshirin is an unknown quantity at this point
Re: CRIO HELP NEEDED!
We had the same sort of problem at the beginning. I think we had to flip some of the cRio's switches. I know we had to turn off safe mode, but I can't remember exactly what else we did.
If that happens to be your problem, I could post a close up of our switches tomorrow.
Prototypes ARE the final product.
Unread 18-02-2011, 21:15
AKA: Jose Ramirez
Team Role: Driver
we turned the safe mode switch and now were trying to format it that way and its been on the reboot phase about 15 minutes now. if you have any ideas or help it would be greatly appreciated.
Unread 18-02-2011, 21:36
Kyoshirin's Avatar
Renaissance Man
AKA: David
FRC #1188
Ok, I just asked our main programmer and he said "Turn off all wireless connections, wired connections, firewalls, security programs. Make sure the safe mode dip switch is off and that the ip app dip switch is on"
We also had to use our camera's crossover ethernet cable to make it work right.
Lemme know if it works, cause I don't have any other ideas.
Unread 18-02-2011, 21:55
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Also make your subnet mask is set properly: 255.255.255.0
(also make sure the rest of the static IPs are correct as well)
Unread 18-02-2011, 22:55
Exernie Exernie is offline
FRC #3080
Exernie is an unknown quantity at this point
can you post a picture of what the switches should look like? please and thanks
Unread 18-02-2011, 23:04
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
when it says that just manually reboot your robot and it should be fiine
Unread 19-02-2011, 00:22
garyk garyk is offline
Programming Mentor: 668, 972, 2643
FRC #0668 (Apes of Wrath)
garyk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the rough
It looks like this article will tell you what you need to do. http://www.chiefdelphi.com/forums/sh....php?p=1022042
Note especially the use of the crossover LAN cable if you connect the cRIO (port 1) directly to your computer. The crossover cable is the orange LAN cable usually used to connect port 2 of the cRIO to the camera.
I couldn't get the referenced NI document but this one is similar:http://www.bu.edu/bua-robotics/files...RIO_Manual.pdf
I'm uneasy about experimenting with our cRIO this close to ship date but I'll experiment with this procedure for my pre-season classes next fall
Silicon Valley Regional 2005, 2006 972
Silicon Valley Regional 2007 668 Xerox Creativity Award
Championship Event 2007 668
Portland Regional 2008 668
Silicon Valley Regional 2008 668, 972
Beta Test Team 2008 668 (with 100 & 254)
Silicon Valley Regional 2009 668 Regional Chairman's Award; 2643
Sacramento Regional 2009 668 Winning Alliance (thanks, 1717 & 2473!), 2010 Winning Alliance 3256
CalGames 2006, 2007, 2008, 2009, 2010, 2011 Field Tech
NorCal FTC Regional 2008, 2009 Inspector
Championship Event 2009
San Diego, Silicon Valley Regionals; Champ. Event 2010 668, 2643, 3256
Silicon Valley, Madera Regional 2012 2643
WRRF Programming Instructor 2006-2016
Regional Woodie Flowers Award 2014 2643 Utah Regional
Unread 19-02-2011, 13:25
AKA: Jose Ramirez
Team Role: Driver
so now we fixed the crio. thanks to everyone who helped us out. Problem now is that we cant seem to get it powered up.
Unread 19-02-2011, 18:32
plnyyanks's Avatar
AKA: Phil Lopreiato
check that the 24V power goes from the PD board to the cRIO (there are 4 possible connections on the connector, and you should use the two outside ones for the RIO. I forget which side is positive and which side is negative)
