Go to Post I'd say it is somewhat addicting. But I think that is a good thing. It proves that knowledge can be addicting. How cool is that? Now, if we could just get everyone addicted to knowledge, just think of what we can accomplish.:D - Molten [more]
Unread 17-02-2011, 12:32
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
Re: Robot Arm Victor Motor
Originally Posted by Robby Unruh View Post
What do you mean "leaving the scope"?
An object only exists when in scope. For instance if you declare a variable in a method it is created and destroyed when the method is entered and exited.
I usually declare a motor in a class and call that classes constructor from my top level class (I use SimpleRobot usually) that way the motor exists from when the class is first instantiated and never goes away until exit.
The scenario I mentioned in the previous post only occurs when you do something like
public void motorStuff(){
motor = new Jaguar(1);
Jaguar.set(0.5);
The motor controller object will go away before it has time to do anything. Even if you call it repeatedly it won't last long enough to run for more than microseconds.
It doesn't seem to be the problem from the code you posted, but it doesn't hurt to ask.
Unread 17-02-2011, 13:26
Jared Russell's Avatar
Taking a year (mostly) off
...and is blinking orange.
To me, this remains the most conspicuous clue. A blinking orange speed controller is one that does not have a working connection to a properly configured PWM port on the digital sidecar. Be absolutely, positively sure your PWM connector is fully seated at both ends.
Unread 17-02-2011, 15:03
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
Our mechanical team is tinkering with it now. I'll let you guys know what happens in the end. Thanks for all the advice.
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 18-02-2011, 23:56
DCRich DCRich is offline
FRC #2180 (Zero Gravity)
DCRich is an unknown quantity at this point
Try connecting the arm to a pwm port with an address less than 9 (ie. 1 to 8). I have not personally used so many motors in the past but the schematics show that channels 9 and 10 are wired slightly differently than 1 - 8. You should try using a higher pulse duty cycle. Finally check to make sure that the black wire in the WRB cable is in the correct position. Victors allow the wire header to be inserted backwards.
