Go to Post It's nice to see how patient people will be on here even with people who are 99.9999% trolling. Something something GP. - Chris is me [more]
Unread 18-02-2011, 18:36
tdonnelly tdonnelly is offline
FRC #3268
tdonnelly is an unknown quantity at this point
Number of Jaguars used?
I was looking through the rules but didn't see anything specific about the number of Jaguar's that can be on the robot. Is there a limit to the number of Jaguar's that can be on the robot?
Unread 18-02-2011, 18:41
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Number of Jaguars used?
Weight / Cost limits.
Of course, PWM outputs avaliable are also a limiting factor. As are the slots on the PD block.
And I think CAN only goes up to 60ish?
Unread 18-02-2011, 19:31
Originally Posted by Zuelu562 View Post
There is no specific limit expressly stated in the rules. By the use of the PD board, however there can be a maximum of 8, in any combination, of the Jaguar speed controller or the older Victor speed controller (limited by the number of 40 AMP breaker slots available).
You are allowed to run a speed controller with a smaller breaker.
Unread 18-02-2011, 19:38
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Then yes, Weight restrictions and what you can afford to get limit the number of speed controllers.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 19-02-2011, 00:46
The Lucas's Avatar
CaMOElot, it is a silly place
Jaguar's can network is limited to 16 nodes according to the Getting Started Guide. You could also use Y-Cables on each of the 20 total PWM ports on 2 sidecars for up to 56 (2*20+16=56) Jaguars controlled. You might be able to use multiple Y-cables on a single PWM output, I don't know the max fan-out.
Of course this exercise is done purely out of curiosity to see how many Jags you could control. The motors you could control with the Jags is limited to 13, including 4 CIMs, 4 total Banebots motors, 4 window motors (which have issues with Jags), and 1 FP motor. The extra CAN Jags could be used to read sensors, but I am not sure what you would do with the extra PWM Jags. Perhaps, you could use their 3 color LEDs to signal which tube you want next to your Feeder
Robot Inspector
Unread 19-02-2011, 02:38
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
You can control as many jags as you want with one channel of PWM (unless you do so many you get limited by current or something... not likely with a 20A breaker).
Cost restrictions say 41 max, if you use nothing else but KOP parts. Christmas tree please?
Unread 19-02-2011, 08:18
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
I think you've got the answer already, now for some real world, practical examples We're using 7 Jaguars this year. http://www.chiefdelphi.com/media/photos/36211
All 7 run on CAN bus without a problem.
Unread 19-02-2011, 08:56
I think there is a buildout limit on the PWM driver that would limit this.
