Go to Post FIRST is all about going past theoretical limits. - Foster [more]
Unread 18-02-2011, 23:21
pfreivald's Avatar
AKA: Patrick Freivald
1551's encoder-controlled arm
This is the most complex thing we've ever coded... But thus far it appears to be easy to use and very precise!
http://www.youtube.com/watch?v=gTLMkUmhU2Y
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 19-02-2011, 00:16
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: 1551's encoder-controlled arm
Looks very nicely controlled. That end screw "skewer" sticking out the front makes me a little nervous, though...
--Ryan
FRC 766, 2015-, Mentor
Unread 19-02-2011, 01:09
coldfusion1279 coldfusion1279 is offline
AKA: Mike
FRC #1279 (Cold Fusion)
coldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud of
That's a great color. Good work.
Cold Fusion's 10th Season
Unread 19-02-2011, 03:33
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
--Ryan
I agree. if you have time, I would work on training your driver to protect that "skewer" from impact. This will both save you from potential penalties, and potential damage to your robot.
I would also be preparing spares for this, and figuring out what the easiest way to replace one of these was, in case it got bent beyond the ability to be screwed out.
on an unrelated note: nice programming! what are you using for feedback?
good luck!
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 19-02-2011, 04:48
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
[quote=Leav;1026498on an unrelated note: nice programming! what are you using for feedback?
[/QUOTE]
The title says encoders.
We're using three accelerometers (one on each part of the arm and one on the chassis) to control ours. I'm still planning for the last minute switch to potentiometers though
Did you use the jaguars' built in PID with the encoders? I'm going to try doing that for our wrist action, and I'm looking for some tips.
Unread 19-02-2011, 08:46
pfreivald's Avatar
A. Encoders with victors. No PID -- it's just not needed on these.
B. We have spares. Several of them. The entire robot is highly modular and easy to replace.
C. The screw should only ever extend out in skewer-like position when we are in scoring position for the middle row -- and thus with nothing in front of us. If the inspectors disagree, we have a plan in place (and a part half-made) to deal with it.
Team 1551
I write books, too!
Unread 19-02-2011, 09:14
Nadav Zingerman Nadav Zingerman is offline
FRC #2230
Nadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to behold
You should do that right now. Accelerometers are terrible for this. You would have to integrate them twice, increasing the noise by more than a factor of two. The noise is quite bad already, and you will probably have a long cable run from the wrist to the controller, probably running next to some electrically noisy motors. If your accelerometer is analog (it probably is), this would make it impossible to use for this task. Even if it's digital, I doubt it can work at all.
Switch to encoders or potentiometers as soon as possible.
Unread 20-02-2011, 01:14
WizenedEE's Avatar
AKA: Adam
We're getting around 5 degrees of accuracy. We're not actually measuring the acceleration of the arm (that's one of the problems) we're measuring the acceleration of something much bigger... gravity.
