Go to Post Brandon Martus, making CD readers' lives easier since May 2001/Fall 98 - Beth Sweet [more]
Unread 12-02-2011, 23:04
Da Kid's Avatar
Da Kid Da Kid is offline
FRC #2957
Da Kid is an unknown quantity at this point
is my wiring good?
i was wondering if my wiring of the minibot is okay. just to make sure i won't be frying anything. we've already had some magic smoke because a wheel got stuck so we've already ordered more motors. here is a paint picture of my wiring. our fuse did get popped early on and we temporarily have a 20 amp fuse from the hostbot in it.
Name:	wiring diagram.jpg
Unread 13-02-2011, 00:07
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Re: is my wiring good?
It's fine, same way ours is hooked up.
Expect the best, Prepare for the worst
Unread 13-02-2011, 03:31
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
If the limit switch stops the motors at the top, what prevents the motors from restarting as the limit switch is pulled away from the top target plate? Limit switches have NC, C and NO terminal markings. for normally closed common and normally open contacts. You need to wire between C and NC if using switch to detect top OR between C and NO if using the switch to detect the pole.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 13-02-2011, 12:57
Da Kid's Avatar
FRC #2957
I understand how the limit switch works though we haven't yet determined for sure where it will be placed or if we're going to actually use two or a "regular household light switch."
Unread 13-02-2011, 13:53
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Make sure you check the current ratings on the switches you're going to use... they need to have a 20A rating to be used safely.
Unread 13-02-2011, 17:04
Kid,
Although your wiring is workable, it will not allow the minibot to be pulled down the post. Think about an addition that will bring the minibot down at the end of the match.
Unread 13-02-2011, 17:49
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We have the same wiring, and it turns off the robot at the top and lets it roll back down the pole.
There's more than one way to mount and actuate a "limit switch". You can do stuff with mechanisms....there's more to life than electronics
Unread 18-02-2011, 12:42
bensherman's Avatar
bensherman bensherman is offline
AKA: Ben Sherman
FRC #1676 (The Pascack Pi-oneers)
Team Role: Electrical
bensherman is a glorious beacon of lightbensherman is a glorious beacon of lightbensherman is a glorious beacon of lightbensherman is a glorious beacon of lightbensherman is a glorious beacon of light
I recommend using a switch that locks in the open position when the bot hits the top. In our testing, limit switches on the top that didn't lock cause issues when taking the bot down. As soon as it starts to slide down, the switch is back in the initial position and will climb the pole again, then repeat. You can make an apparatus to keep the switch in the NO position when it hits, but a push button type of switch is the easiest and (should be) the most reliable.
2011 NJ Regional #1 seed, winner
2011 Virginia Regional winner
2010 New Jersey Regional Winner
2010 Virginia Regional Winner (15-0 )
2010 Curie Finalists
Editor - alltechdaily.com
Unread 18-02-2011, 13:03
Mentor, LRI, MN RPC
A push-button type of switch is not on the approved list of materials for the minibot. Check <R92> - the only type of switches allowed are limit switched (I've never seen a push button marketed as a limit switch) and common household light switches.
Unread 18-02-2011, 13:10
bensherman's Avatar
AKA: Ben Sherman
When I get in today I'll post the model number. We got them off digikey, manufactured by Cherry. They can be pulled out and locked in that position (set for NC for us), and when depressed they stay depressed as NO to disable the bot. Marketed as limit switches in digikey
Unread 18-02-2011, 15:08
Mentor, LRI, MN RPC
That would be awesome... If it's really marketed as a limit switch, it'll solve this problem for a lot of teams.
Unread 18-02-2011, 16:06
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Our team uses the NXT running code so we are not using switches. However, I was just curious about how it could be done with switches. Here is what I came up with and it doesn't look like it needs any DPDT or even locking limit switches. It just needs one NO limit switch and one SPDT household switch. When the minibot deploys, it closes the NO limit switch and starts the motor climbing. After it hits the top, the SPDT switch flips and shorts the motors to ground causing it to brake. Depending on the weight of the minibot, it will either stay up there or slowly coasting down. I also came up with an alternate design where it will reverse the motor so it will climb down but with gravity helping, the minibot will practically crashing down very fast.
ID:	10203  Click image for larger version
Unread 18-02-2011, 16:15
Mentor, LRI, MN RPC
Yup, that's pretty much how you can get it to work! An interesting compromise between the two looks very similar to your first drawing... except you don't short the motor leads when you get to the top. That should allow it to fall a bit easier, without actually being powered down. Essentially, it's the difference between brake and coast mode on the victors/jaguars.
Unread 18-02-2011, 16:24
mikets's Avatar
Software Engineer
Yup, that would work too. In our NXT controlled minibot, we programmed it to brake and it was coming down slowly at a constant speed. That's why I thought you may need to do "brake" mode. But again, it depends on your minibot design and weight.
Unread 19-02-2011, 08:20
If you deliver the robot to the pole and it activates the pole switch, the on/off switch is redundant.
