Go to Post FIRST will continue searching for rules and procedures to keep us from hurting ourselves. However, none of this will substitute for judicious application of common sense. - Richard Wallace [more]
Unread 19-02-2011, 09:25
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Re: 2 NORMAL Switches on a Minibot.
Are they on the official FRC-legal Tetrix parts list, available at http://usfirst.org/uploadedFiles/Rob...ix%20Parts.pdf ?
If not, are they sold either as household light switches or as limit switches?
Is there any other way that you could possibly get them in via <R92>?
Hint: The correct answer is that your plan will need to change. How it will need to change is up to you.
The Tetrix On/Off Switch is on the last page of this document. We are using 1.
