Go to Post When you come down to it, FIRST is about people inspiring other people; STEM and the robots are just the subject matter. - RyanCahoon [more]
Unread 19-02-2011, 10:26
Ryan_Davis Ryan_Davis is offline
FRC #3157 (Iron Lancers)
Ryan_Davis is an unknown quantity at this point
How to conjoin surgical tubing?
We cannot tie the tubing so we neither a step by step on how to melt or glue surgical tubing. Thank you very much in advance, Eastridge Robotics.
"Quality means doing it right when no one is looking."
-Henry Ford
Unread 19-02-2011, 10:35
Re: How to conjoin surgical tubing?
You will destroy the tubing if you try to melt it. There is no glue that is both strong enough and flexible enough to bond with acceptable integrity to the tubing.
Why can't you tie it ?
Unread 19-02-2011, 10:39
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
I usually cut (or stretch) the tubing so that the ends go past each other and then put two zip ties around both ends and cinch them together. Just be careful, some zip ties can cut the surgical tubing when tightened too much.
Unread 19-02-2011, 10:46
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
we have used hose clamps in the past, i have always thought that if you could inflate the surgical tubing with compressed air, then put one end inside the other and let the air out it would make a strong bond.
Thank you both very much, we have decided to forgo the use of surgical tubing.
-Henry Ford
Unread 19-02-2011, 11:07
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Someone else may find this useful...
Cut a short length of pneumatic tubing (2-4 inches will do, longer will make a better bond) and slide both ends of the surgical tubing over it. It's surprisingly strong, although I can't vouch for it's performance under very high loads or over a long period of time.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 19-02-2011, 11:16
AKA: Isaak
Team Role: CAD
i got a better idea, get heat-shrink that just fits over the tube before shrunk, then shrink it.
Unread 19-02-2011, 11:23
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
A smaller diameter length of surgical tubing can be inserted into larger tubing, but it is very difficult. The upside is that it is just as difficult if not harder to remove (this is only a good thing if you don't have to undo the connection once it has been made).
Unread 19-02-2011, 13:23
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Take a look at a wrist rocket slingshot and see how the sugical tubing is attached to the slingshot.
Roy
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 19-02-2011, 16:08
Danger: Do NOT use lubricant to slide the tubing on. It may slide off and hit someone in the eye.
Unread 19-02-2011, 16:15
foote stepped in
AKA: E. Foote
FRC #0868
Would a solvent (such as isopropyl alcohol) work? It should lubricate when its wet, then evaporate quickly afterwards. I believe its what's used to re-grip golf clubs.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
