Go to Post How many programmers does it take to change a light bulb? None. They'll just say it's a hardware problem. - crafty [more]
Unread 19-02-2011, 13:41
microeyes360 microeyes360 is offline
FRC #3687
microeyes360 is an unknown quantity at this point
Photoswitch value?
I know that when calibrated, the photoswitches will shine yellow/orange when over tape, and green when over the carpet.
I just need to know what default value they will return when over both surfaces. The get() method of DigitalInput returns a boolean value, but which condition will return true, and which false. I am guessing that tape returns true, but I really can't test it until the competition since my team does not have access to these materials.
Anybody know?
Also, first post on these forums!
Unread 19-02-2011, 13:47
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
Re: Photoswitch value?
Congratulations on your first post!
What the sensors return depends on how they are wired. Ours originally returned true when over the carpet (green) and false when over the tape (yellow), but now it's the other way around. Write your code so it's easy to change, and test at competitions.
while(!going.isTough());
tough.exit();
What will we do tonight, Warfa?
The same thing we do every night, Patrick. Sit and wait for Electrical.
Unread 20-02-2011, 15:31
Hadyn Fitzgeral Hadyn Fitzgeral is offline
None #1234
Hadyn Fitzgeral is an unknown quantity at this point
A Photoswitch Has 2 Values
On and Off
Or 0/1
This can be translated into binary and using a bitmask we can get values either know as Opcodes to translate into robot movement.
byte mask = 0;
if(sensor0 is active)
mask |= 0x1;
if(sensor1 is active)
mask |= 0x2;
if(sensor2 is active)
mask |= 0x4;
return mask;
MIN OPCODE = 0, MAX OPCODE = 7 [2^0 + 2^1 + 2^2]
