Go to Post The GDC needs to write the rules once and let the game be what the game is going to be. There's little that's fun about being told exactly how to play with your toys. - Madison [more]
Unread 19-02-2011, 12:23
jimmyqwerty jimmyqwerty is offline
FRC #0068
jimmyqwerty is an unknown quantity at this point
frc image V 28
Today the version 28 came out for the crio imaging tool.
When I opened the folder their was no exe, just txt files and some config files. I downloaded this update from first forge, but my question is how am i suppose to install the updates?
thanks
Unread 19-02-2011, 12:53
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
Re: frc image V 28
thanks
On the desktop of your Developer account should be a cRIO Imaging Tool. Plug an ethernet cable from your computer to the cRIO and run it. If you're not already in the cRIO Images folder, navigate to
C:\Users\Developer\sunspotfrcsdk\cRIO_Images
You'll see a file called FRC_2011_v28.zip. From here, let the imaging tool do it's thing and you should be fine.
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 19-02-2011, 13:41
FRC #0068
Re: frc image V 28
I checked the CRIO-images folder and version 28 zip folder is in there but when i open up the imaging tool it says that the available image is Version 27 to send to the robot. so what do i do?
Unread 19-02-2011, 14:13
Re: frc image V 28
Did you have your robot updated to v27 prior to updating to v28? I don't think you can simply skip them like that.
[Robots R Us #3266]
2011: Buckeye
2010: Buckeye
Unread 19-02-2011, 14:25
FRC #0068
Re: frc image V 28
We already had updated the CRIO to v27
Unread 20-02-2011, 07:44
OJ_Helms OJ_Helms is offline
FRC #3011
OJ_Helms is an unknown quantity at this point
Re: frc image V 28
Team 3011 here.
We are having somewhat the same problem.
After we got the classmate to locate the updates, we tried to run the cRIO imaging tool.
For some reason v28 comes up with errors saying that the current IP address is used.
Our classmate IP is: 10.30.11.5
Subnet: 255.0.0.0
