Go to Post Your attribute of personal sacrifice is very noble, but FIRST needs YOU to be successful first. - DanKein [more]
Unread 19-02-2011, 11:33
cilginbilgin cilginbilgin is offline
FRC #2905
cilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the rough
Exclamation No Wireless Communication but Yes Wired
When we attach the ethernet cable between c-RIO and classmate we can communicate with the robot but when we try wireless connection, communication fails. We have configured the D-Link (Radio) properly but when we try wireless connection, on Driver Station c-RIO Image is unavailable but in wired connection it shows the v28 Image..
I'm waiting your help!!!
Unread 19-02-2011, 15:12
Re: No Wireless Communication but Yes Wired
Is the Classmate able to see the "2905" wireless network? Is it able to connect to that network? Once the wireless connection is made, what IP address does your Classmate have?
Unread 19-02-2011, 15:44
FRC #2905
Classmate is able to see the "2905" wireless network and it is also able to connect to network.
The IP address of the classmate is 10.29.5.5
Subnet Mask 255.0.0.0
Default Gateway 10.29.5.2
Unread 19-02-2011, 20:27
The default gateway ought to be 10.29.5.1, the address of the DAP.
Unread 20-02-2011, 07:22
MattCarey3625's Avatar
MattCarey3625 MattCarey3625 is offline
#3625 Programming and Wiring Head
FRC #3625 (Some Assembly Required)
MattCarey3625 is an unknown quantity at this point
I agree with the above post, the only other thing I could think of is that the cRio project is not aimed at the correct ip.
matt@hp-mini-110$> sudo make robot
sudo pass for matt:
unable to make robot
Unread 21-02-2011, 12:20
2bkrul's Avatar
2bkrul 2bkrul is offline
Whats tht burnin smell..oh the Jag!
AKA: Brandon Krul
FRC #0964 (Bedford Robotics)
2bkrul is an unknown quantity at this point
I have the same problem, when I try to connect to the robot wirelessly, it wont connect. It connects on every other computer we have. all of the information is set up correctly for the static IP but it wont work.
The bad thing is, I cant connect on our programming laptop
"Building robots is a lot better with doughnuts around"
-Team 964 2010 Team Motto
Team 964 on TBA!
The Home of Bedford Robotics!
Unread 21-02-2011, 20:16
The wired and wireless connections have unique configurations for the NIC (Network Interface Controller). They may be on the same subnet, but they cannot be at the same IP at the same time. Be sure to look at the ipconfig or better yet, the adapter properties for IPV4 and determine if the Wireless is setup for the team IP and unique. By default the DS uses 10.te.am.5 and 10.te.am.9.
Once the Wireless IP is set, make sure the laptop wifi is on, and you should be able to click on the network glyph on the system tray. Do you see the team network listed? Is is connected? If the other laptops list the name otherwise known as the SSID, check to see the frequency of the laptop wifi and compare that to the dlink. It is possible to pick a frequency range that will not work with all laptops.
Greg McKaskle
