Go to Post Ultrasonic sensors will allow you to do fundamentally the same thing that the bump sensors do...so you can slow down and smoothly stop your robot just before it reaches the end wall, instead of running into it at full speed and then figuring out "ohh! there is a wall there!" - dlavery [more]
Unread 19-02-2011, 13:06
Wrmwolf Wrmwolf is offline
AKA: Victor
FRC #3477 (Chaos Vortex)
Team Role: Animator
Wrmwolf is an unknown quantity at this point
Attaching a piece to a window motor
After asking in the forum, I was adviced to use a window motor. Now the problem is that I cant connect the adapter to it, it fits, but it does not stay there. The collar will not fit around it. Ill put a picture of the window motor and the adapter bellow.
Unread 19-02-2011, 13:45
sami9145's Avatar
sami9145 sami9145 is offline
AKA: Samantha Gainey
FRC #2333
sami9145 will become famous soon enough
Re: Attaching a piece to a window motor
You have the wrong collar then.
Team 2333 used 2 different window motors last year and the collars are not universal. Look around to find a different one or find another window motor that works with your collars. Then it should all work fine.
FRC Team 2333
2008-2009 team member
2009-2010 co-captain
FTC Team 3679
2009-2010 team captain
Unread 19-02-2011, 14:31
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
If I understand the problem correctly, the adapter does fit, but it's falling off.
This is the normal situation for the adapter. there are many solutions to this, ours is to tap the metal axle in the center of the motor, and screw in a bolt with a washer to keep the adapter in.
it's a quick and easy solution, but if you overtighten and have the motor running in the direction that will unscrew the bolt, it might be trouble.
LockTite or similar is advised.
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 19-02-2011, 15:33
Nemisis's Avatar
Nemisis Nemisis is offline
Frame/Body/Motors
FRC #2389 (S.T.O.R.M.)
Nemisis will become famous soon enough
We gorilla glued the adapter straight onto the window motor and it worked fine lol
RHS Senior 2011
