Go to Post I'm pretty sure there is a federal sequester on the bandwidth coming out of LSR. - PayneTrain [more]
Unread 19-02-2011, 16:30
MisterL's Avatar
MisterL MisterL is offline
Robot C Master and Mentor
AKA: Derrick Canfield
FRC #1544 (One Byte Short)
MisterL is an unknown quantity at this point
Re: Autonomous Photosensor Programming
This is all helpful, I only wish I had more expertise in Java. This is still kind of a new thing for me to learn so I am completely out of my league. Thank you for your help! If you are able to help a little more on the
if(middle.get())
concept that would help. I can't help but feel I am missing something here.
"Doing Java from scratch with no previous experience with it? Piece of cake!" Famous Last Words
One Byte Short Mentor
Unread 19-02-2011, 16:47
ArchVince's Avatar
ArchVince ArchVince is offline
FRC #1290 (Si Se Puede)
ArchVince will become famous soon enough
if(middle.get())
The line sensors send true if a line is underneath and false if there is not a line underneath. The get method return that value. Basically, middle is the digital input plugged in to slot 1. if(middle.get()) checks to see if there is a line underneath that sensor. That's my impression of it, anyway. We only used line sensors temporarily, since we aren't sure if we'll even have a functioning arm to use with them.
PETA wants your help finding Schrödinger.
Unread 19-02-2011, 19:41
MisterL's Avatar
Well heres a new development, we only own one photosensor, so should I only have the middle part of the code? Or should I use a whole new code?
Unread 19-02-2011, 20:36
Bot190's Avatar
Bot190 Bot190 is offline
FRC #0166 (ChopShop)
Bot190 will become famous soon enough
You should have gotten three of the photoelectic sensors in the Kit of Parts.
As others have said, you want to put the three line sensors in a row, spaced apart a little. Then you have to adjust them such that the LED's on the sensors change colors as you move the robot past the tape.
Then, depending on how you wired them, you will get a value from the sensor with a digitalinput. The Get method returns a value, 1 or 0 when the sensor sees the line, or doesn't, depending on how you wired them.
From there, you basically go forward while the center one is on the line, then if either side sees the tape, turn a bit until only the center sees the line.
Unread 20-02-2011, 15:26
Hadyn Fitzgeral Hadyn Fitzgeral is offline
None #1234
Hadyn Fitzgeral is an unknown quantity at this point
Here's my teams code that I wrote for this. We can do the Y + the straight profiles of the line. Since this is fairly outdated I am not to worried about leeching.
 * To change this template, choose Tools | Templates
 * and open the template in the editor.
package org.freelance.logic;
import edu.wpi.first.wpilibj.Timer;
import org.freelance.sensors.Photoswitch;
import org.freelance.sys.MecanumDrive;
import org.freelance.util.Constants;
 * @author Freelance Robotics (Hadyn Fitzgerald)
public class Linetracking {
    private boolean done = false;
    private boolean left = false;
    private int profile = 1; //1 == Y, 0 == Straight
    private Photoswitch leftSwitch;
    private Photoswitch centerSwitch;
    private Photoswitch rightSwitch;
    private final byte NONE_OPCODE = 0, LEFT_OPCODE = 1, CENTER_OPCODE = 2,
                       RIGHT_OPCODE = 4, ALL_OPCODE = 7;
    private double FORWARD = -.5, BACKWARD = .5, LEFT =  -.425, RIGHT = .425;
    private int stage = 0;
    public Linetracking() {
        initLineTracking();
    private void initLineTracking() {
         * Construct Photoswitches
        leftSwitch = new Photoswitch(Constants.LEFT_SLOT);
        centerSwitch = new Photoswitch(Constants.CENTER_SLOT);
        rightSwitch = new Photoswitch(Constants.RIGHT_SLOT);
    public byte getType() {
        byte type = 0;
        if(leftSwitch.get())
            type += 1;
        if(centerSwitch.get())
            type += 2;
        if(rightSwitch.get())
            type += 4;
        System.out.println(type);
        return type;
    public boolean process(MecanumDrive drive) {
        byte type = getType();
        switch(type) {
            case NONE_OPCODE:
                if(profile == 0) {
                    drive.controllerDrive(0, 0, 0);
                } else
                    if(stage == 0) {
                        for(int a = 0; a < 50; a++) {
                            if(left)
                                drive.controllerDrive(0, 0, -.3);
                            else
                                drive.controllerDrive(0, 0, .3);
                        while(getType() != CENTER_OPCODE) {
                            if(getType() == ALL_OPCODE)
                                break;
                            if(left)
                                drive.controllerDrive(0, LEFT, 0);
                            else
                        stage++;
                    } else if(stage == 1) {
                        for(int a = 0; a < 35; a++) {
                            if(left)
                            else
                        done = true;
                    } else {
                break;
            case LEFT_OPCODE:
                    if(getType() == NONE_OPCODE || getType() == ALL_OPCODE)
                        break;
                    drive.controllerDrive(0, RIGHT, 0);
                break;
            case CENTER_OPCODE:
                drive.controllerDrive(FORWARD, 0, 0);
                break;
            case RIGHT_OPCODE:
                        break;
                break;
            case ALL_OPCODE:
                if(profile == 0) {
                    done = true;
                break;
        return done;
    public void reset() {
        stage = 0;
Unread 20-02-2011, 20:17
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
How are you guys programming your Y's? I'm having some trouble with mine. Any tips would be really appreciated.
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 20-02-2011, 21:21
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
Our robot drives straight on the line, so it notices when the middle sensor is no longer over the tape, but the left and right both are. At that point, we begin turning in the direction we want to go. Using the code you've already posted as a template:
if(left.get() && !middle.get() && right.get()) {
        // turn left or right, depending on what you want
It wouldn't go on as another else, it would be a separate if, or it would never be triggered.
while(!going.isTough());
tough.exit();
What will we do tonight, Warfa?
The same thing we do every night, Patrick. Sit and wait for Electrical.
Last edited by Patrickwhite : 20-02-2011 at 21:29. Reason: forgot to write the point of the post
