Go to Post OK, repeat after me "FIRST is not about the robot". - Foster [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 19-02-2011, 16:41
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
CAN error help
ok so weve been dealing with this all day now.
when we turn on our robot we get ERROR<Code> -44087 Occurred at NetComm_Can_Recieve.vi:8
and then when we enable the robot
ERROR<Code> -44087 Occurred at NetComm_Can_send.vi:6
from posts on the fourms we have verified both our terminators work ( am I able to enumerate all the jags with the BDC COMM tool and set their positions and voltages and such)
I places 100ms second waits on both the teleop and dashboard main loops( per http://www.chiefdelphi.com/forums/sh...ad.php?t=91102)
im still at a loss for these errors
I m running labview 3.1 and the cRio has version 28 on it.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 19-02-2011, 22:18
Stuart's Avatar
#include coffee.h
Re: CAN error help
ok so Error send:6 and Receive:8 are from when a CAN ID in your code is unreachable.
so if you see this check the power connections to the jags to make sure every thing is secure.
Unread 20-02-2011, 01:13
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: CAN error help
It sounds like you haven't installed the BlackJag Plugin.
You can do this from the cRIO reimaging tool.
-- Marshal Horn
Unread 20-02-2011, 05:34
Stuart's Avatar
#include coffee.h
Re: CAN error help
no that was installed. the problem was one of the Jags came unplugged ( power ) and therefor was unreachable
