Go to Post Engineering rules of thumb don't form the garbage that goes into the making of the robot. They take the garbage of the real world and turn it into more pure, if slightly diluted, data. - DampRobot [more]
Unread 19-02-2011, 13:29
dmitch's Avatar
dmitch dmitch is offline
Chief Head Electrical Guy
AKA: Daniel Mitchell
FRC #1997 (Stag Robotics)
dmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the rough
robot code not deploying
Hey guys sorry if this has been posted but when I build an run as startup or when I I run hr robot main code it goes through the steps of deploying and we open up the driver station it gives us a red light next to robot code
Unread 19-02-2011, 19:19
Re: robot code not deploying
Check the version of the cRIO image. Also, does the VI run interactively, using the run button?
Greg McKaskle
Unread 19-02-2011, 21:00
MattCarey3625's Avatar
MattCarey3625 MattCarey3625 is offline
#3625 Programming and Wiring Head
FRC #3625 (Some Assembly Required)
MattCarey3625 is an unknown quantity at this point
Check to make sure your image in the cRIO Imaging tool is not 'unknown' and try restarting the robot. We have this problem quite frequently as well.
matt@hp-mini-110$> sudo make robot
sudo pass for matt:
unable to make robot
Unread 19-02-2011, 21:31
Just to make sure:
You aren't quitting LabVIEW before starting the Driver Station application, are you?
