Go to Post Maybe it just seemed like five hours...I had freshmen in my vehicle! - Qbot2640 [more]
Unread 19-02-2011, 20:09
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Exclamation Victors not working please help
So this is our first year of using a second side car and its not working... here is the code:
vicShoulder(6,10);
we have power to the second side car and all the lights come on we do not have a light connected to it. we have the the power and connected. when we turn on our robot the victor status light blinks orange. we have tried these things:
  • switching pwms
  • swithing the pwm to the first side car and chaning the code
  • switching ports on the second side car
  • hooking up one of our jaguras to the pwm in the first side car
and it still blinks orange
any ideas?????????
Unread 19-02-2011, 22:12
Re: Victors not working please help
anyone?
Unread 19-02-2011, 22:20
CodeMonkeyMatt CodeMonkeyMatt is offline
FRC #2605
CodeMonkeyMatt is on a distinguished road
Is it safe to assume that you declared vicShoulder as a Victor and not a Jaguar?
Can you get a Jaguar working on the second sidecar?
Unread 20-02-2011, 00:17
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Could you post a more thorough section of the code, rather than one line? It'd help us a lot more in figuring things out.
Attending: MN Duluth Regional
Unread 20-02-2011, 00:34
dboisvert dboisvert is offline
AKA: Dan Boisvert
FRC #2405 (Divided by Zero)
dboisvert is an unknown quantity at this point
Make sure you are declaring the victor properly
Victor* vicShoulder;
Further down, you should have something along these lines
Where the PWM number is where you plug it into your digital sidecar
vicShoulder = new Victor(PWMNUMBERHERE);
Once the victor has been declared and constructed you need to actually call it or set it to some value
vicShoulder->Set(float value of speed);
Remember that once you set it you will want to also shut it back off by sending it a 0
Make the appropriate changes, and if still does not work put a multimeter on the proper pwm output channel to see if its a bad victor or not.
Unread 20-02-2011, 01:42
FRC #2605
Actually dboisvert, I suspect that tomy's writing his code based off the simple robot class, which doesn't use pointers, but creates objects directly. For that the syntax would be*:
Victor vicShoulder;
Then at the robot constructor:
RobotClassName():
vicShoulder(slotNum, portNum)
And then to use it:
vicShoulder.Set(speed);
Someone correct me if I'm wrong, especially tomy if this isn't how you're attempting to run the Victor.
I agree on your other points though. I don't know how many times I've forgotten to turn off a motor, or how many times I've poured through my code only to discover an electrical failure was the problem.
Also agree with theprgramerdude, more code = more help.
*This was from memory, so it might be off a little. Idea's the same though.
Unread 20-02-2011, 02:12
WPI Freshman
AKA: Alex
I believe Code Monkey has it exactly correct. Also, be sure you're not wiring the PWM cable in backwards to the Victor, as there are no markings if I can remember right on the case. In addition, make sure you initialize it right, with the ClassConstructor():
blablaobject(stuff),
morestuff(otherstuff),
vicShoulder(6,10) <- These lines are where you should make sure to initialize the constructors, and they have to be in the order you specified them in the class template.
more stuff here...
Unread 20-02-2011, 09:09
this is parts of our code:
RobotClass;
             Victor vicShoulder;
RobotVoid;
             vicshoulder(6,1);
WhileinOperatorControl{
if(armstick2.getY()){
    vicShoulder.set(armstick2.getY);
i believe that is what we have
could it be an older victor that we cant program anymore cause we got stuff from an older team and the victors look old but they turn on and the fan works its just that the light blinks orange
Unread 20-02-2011, 10:11
WPI Freshman
AKA: Alex
Well, the first part looks funky and strange to me, as its still a bit out of scope (referring to, we need the code around the lines too), but what really caught my eye was the last few. Your "if" code makes no sense; what it's doing right now is getting the Y value off the joystick and checking whether its centered or not... that, and the Set command requires a capital S. Why not just remove the if statement altogether? It's useless.
All Victor 884's are the same; to my knowledge they haven't changed since they came out.
At the top of your code you have
vicshoulder(6,1);
For one thing, the S isn't capitalized again, and.... you need to initialize the Victor object in the class initilization section above the braces.
I'll put some of my similiar code here later.
Unread 20-02-2011, 10:21
Mr. Lim Mr. Lim is online now
AKA: Mr. Lim
Check that the PWM cable is inserted fully into the Victor, and all the pins are lining up perfectly straight into the connector. Sounds simple, but is often incredibly hard to do. The easy way to check is to pull the PWM cable out of the Victor, and if any, or all of your pins aren't PERFECTLY STRAIGHT, then you likely inserted it wrong. Even the slightest bit of deflection means that you likely missed the connector inside the Victor.
Inserting your PWM cable into the Victor should take almost no downward force, if aligned perfectly. If you have to push a little too hard to get the connector in, you've plugged it in wrong.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 20-02-2011, 11:19
Lol that was the wrong if statement
We are using two sensors with our shoulder joint and I do not have the code with me at the moment
Unread 20-02-2011, 12:33
Could it be that in my code i have an if statement that means this:
if the arm is triggering the front sensor the shoulder will not move unless you give a negative value. and if it is on the back sensor it will not move unless its on the front sensor.
But we do not have the senors hooked up yet, so could that be it?
For right now without the sensors on there cant i just do something like this to drive my shoulder joint?
vicShoulder.Set(armstick.GetY)
Unread 20-02-2011, 15:25
or do i have to something like this?
vic.Shoulder.Get(armstick.GetY);
or this
vic.Shoulder.Set->(armstick.GetY);
Unread 20-02-2011, 18:19
anyone got advice?
Unread 20-02-2011, 18:24
FRC #2605
If you're trying to read data from sensors that aren't hooked up and using that to determine whether or not to move, that could by your problem.
To run the Victor, you'll want the first one you posted. I'm sure you had the wrong syntax because you were typing from memory, not because you don't know it, but make sure it's
vicShoulder.Set(stickName.GetY())
Not
vicShoulder.Set(stickName.GetY)
Note the parentheses. If you don't have it, it should give a compiler error though, so probably not your problem.
