Go to Post if sleep is essential, then yeah, I'm in trouble. - Eria4044 [more]
Unread 19-02-2011, 21:13
MattCarey3625's Avatar
MattCarey3625 MattCarey3625 is offline
#3625 Programming and Wiring Head
FRC #3625 (Some Assembly Required)
MattCarey3625 is an unknown quantity at this point
Re: Arm problem with PWM in teleop code
Anything involving PWM should remain constant. There is no reason I can thin of that would require you to use the front panel between stages. Use a 'Constant' instead of 'Control'.
matt@hp-mini-110$> sudo make robot
sudo pass for matt:
unable to make robot
