Go to Post if you want FIRST people to sign a petition, July isn't the best time to do it. - Pault [more]
Unread 20-02-2011, 09:11
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Incorrect voltage readout on Driver Station
Originally Posted by cilginbilgin View Post
Another thing to add that issue our driver station always reads 0 voltages whenever we are connected to robot.
Does someone know how to fix this problem?
Common causes of this are not installing the jumper on the Analog Breakout and not powering the Analog Breakout board.
The jumper should be installed on the outside two pins of the 3 pin header.
The Analog Breakout requires 12V power from the Power Distribution board in order to run.
The Analog Breakout Datasheet provides more detail if you need it:
http://www.usfirst.org/uploadedFiles...out%281%29.pdf
