Go to Post There is a fine line between genius and insanity, watch your step! - Al Skierkiewicz [more]
Unread 20-02-2011, 09:54
Mr MOE's Avatar Woodie Flowers Award
Mr MOE Mr MOE is offline
MOE 365 Team Coordinator
AKA: John Larock
None #0365 (Miracle Workerz)
Mr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond repute
Re: LogoMotion Learnings from Scrimmages
Great comments everyone! Keep 'em coming!
-J-
MOE Celebrates 18 Years in FIRST this season!
2007 CMP Chairmans Award - thanks to all MOEboteers, past and present!
Unread 20-02-2011, 10:16
Andy Grady Andy Grady is offline
I'm done being quiet!
FRC #0131
Rookie Year: 1995
Andy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond repute
Send a message via AIM to Andy Grady
Hello everyone,
Most gameplay points that I saw have already been made by others, though I don't think you need to push a tube against a wall to pick it up. Roller claws seemed to deal with floor pickup very well.
A couple of pointers for your first week event...
1. Get your minibots secure. Many times teams were penalized because minibots were just falling off of robots under normal robot movements. Even worse, sometimes those minibots were hit by big robots...not a good thing.
2. Make sure all your software, firmware, etc. are up to date. Most of the delays yesterday came as a result of teams not updating to the most recent software updates. If you do this, you will raise your chances of not missing your first practice round on thursday.
3. Always come to the field with a full battery. Battery voltage dips heavily as more load is placed on it. The C-Rio will reboot if battery voltage gets too low. Make sure you are always equipped with a battery that has ample voltage checked by meter (slightly over 13 volts or more is a good guideline)
4. Know the rules. Many teams were getting penalized needlessly because they were doing things that were just puzzling.
These are just a few things that will make life easier on you, and on the FTA's and staff on competition day.
Good luck to everyone!
Unread 20-02-2011, 10:41
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Be conscious of how inflation level of tube effects your manipulator. At Suffield the tubes were inflated to a level I didn't think was possible without popping them. Thankfully we built in adjustability, but I think a lot of teams may be in trouble.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 20-02-2011, 10:47
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Originally Posted by gyroscopeRaptor View Post
Also, ground-pickup is near impossible unless you are picking from at the wall.
I expect the problem is that most manipulators are designed to pick up from the robot side of the tube, and instead of grabbing it, they push the tube away from themselves. Ours picks up from the center, we run into the tube, drop the manipulator into the middle, and lift it up. We made the other type of claw in 2007 and had the same problems you witnessed.
Unread 20-02-2011, 11:01
MarcD79's Avatar
MarcD79 MarcD79 is offline
AKA: Marc
FRC #0176 (Aces High 176)
MarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond repute
Smart feeders are a must.
It is possible. Here at Suffield Shakedwon, there were a variety of robots, including team 176. 176 just slid their arm slightly from the side & clamped down They didn't need an immobile object to push against.
Mentor & Volunteer
Field setup, Field Supervisor & disassemble Suffield Shakedown 2003- present (2015)
Connecticut Regional Field setup, disassemble & FTAA 2009, 2010, 2011, 2012, 2013 (Field reset & Assistant Field Supervisor), Field Reset Pine Tree Regional 2013, Field Supervisor, setup & take-down at Groton & Southington Districts 2014, Field Reset Hartford District 2014. Field Reset Boston District Championship 2014. FLL Judge Fall 2014
Field Supervisor/Set-up & Take-down Waterbury & Springfield , Field Reset/Set-up & take-down Hartford N/E District 2015. Field Reset NE Champs 2015. FLL Judge Fall 2015.
Suffield Shakedown 2016, Field Super 2016 Stronghold Waterbury.
Unread 20-02-2011, 11:04
MarcD79's Avatar
AKA: Marc
All tubes at Suffield were inflated to FIRST specs. I think what happened to teams is they didn't inflate using the official template for inflation.
Mentor & Volunteer
AcesJames's Avatar
AcesJames AcesJames is offline
Mentor, still learning
AKA: James Temple
FRC #2170 (Titanium Tomahawks)(EWCP)
AcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond repute
Send a message via AIM to AcesJames Send a message via MSN to AcesJames
Observations @ Suffield
1. There wasn't much defense, even in eliminations. Moreover, it was just traffic of robots clogged in the center of the field looking for tubes. Teams were too pre-occupied with filling their own racks that defense seemed time consuming and impractical.
2. Tubes were extremely inflated, to the point that some teams' grippers didn't open enough to actually wrap around the tube wall, and instead just pushed the tube around.
3. Mini bots fell of their robots, a lot.
4. Mini bots decided the round, every round they were actually deployed.
5. Coordinating when each of the 3 robots is at the feeder station, and when each is at the rack is tough, and miscommunication leads to huge slowdowns and incomplete logos.
FRC 176 - Aces High - 09-12 - Student
FRC 229 - Division By Zero - 13-14 - "Mentor"
FRC 2170 - Titanium Tomahawks - 17-Now - Mentor
Unread 20-02-2011, 11:09
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
This picture seems to disagree:
http://www.chiefdelphi.com/media/photos/36416?
The middle triangle is clearly way too big if all the other tubes in the picture are inflated to spec. The top square is likely overinflated as well.
Unread 20-02-2011, 11:26
GaryVoshol's Avatar
Cogito ergo arbitro
What specs were violated?
2.2.9 GAME PIECES
While playing LogoMotion, HOSTBOTS manipulate GAME PIECES to accomplish the objectives of the game. Each GAME PIECE is an inflatable object constructed of 0.3 mm thick vinyl. The body of each GAME PIECE has a tubular cross-section, nominally between 7 and 8 inches in diameter at their narrowest. The GAME PIECES are inflated to nominal size, not a specific pressure.
2.2.9.1 LOGO PIECES
During the majority of the MATCH, the HOSTBOTS manipulate GAME PIECES that are constructed in one of three shapes: a TRIANGLE, a CIRCLE or a SQUARE. The exterior dimensions of the GAME PIECES range between 25 inches (from side to side of the SQUARE) to 30 inches (from corner to corner of the TRIANGLE). The central opening in each GAME PIECE ranges between 9-1/2 inches (for the TRIANGLE) to 12 inches (for the CIRCLE and SQUARE) across. The TRIANGLE GAME PIECES are colored red, the CIRCLES are white, and the SQUARES are blue.
(emphasis mine)
Especially note the nominal dimension for thickness is a minimum, not a maximum.
(since 2004)
Unread 20-02-2011, 11:30
kborer22's Avatar
kborer22 kborer22 is offline
kb
AKA: kb
FRC #0125 (Nutrons)
kborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud of
Send a message via AIM to kborer22
1. Top row is king. It takes just as much effort to score on the top as it does on the middle row.
2. Know your opponent and pick you strategy wisely. For example at suffield a team would score an ubertube on the middle row during auto. That alliances' default move from there was to complete a logo on that middle row. In the mean time the opposing alliance was completing a logo on the top row. The team that scores on the top won every time, of at least what i remember.
3. There will be a lot more scoring in auto than in past years. There were several teams at the scrimmage that were scoring, or almost scoring (125 included, 3 times we placed the tube over the peg, but didn't release). I think the combination of previous experience with tubes (2007) and the fact that the pegs are fixed will make for more auto scoring that most people are used to.
4. Mini bots are game changers.
5. The field seems smaller than i expected. Lots of robots and tubes in the middle make for tons of congestion.
6 Extremely difficult to see/align tubes from across the field.
NUTRONS 125
2007 Boston Regional Champs (125, 126, 69 NU-Hyper-Force!)
MORTTeam 11
2004-Palmetto Regional Champs
2004-Palmetto Regional Daimler Chrysler Team Spirit Award
2005-NJ Chairman's Award Winner
Unread 20-02-2011, 11:52
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
(emphasis mine)
I read that to mean that the narrowest part (ie. the middle of a triangle edge) of a properly inflated tube should be between 7 and 8 inches, I certainly could be wrong though. If that triangle didn't even fit through the feeding slot as was reported don't you think it may have been on the large side?
Unread 20-02-2011, 11:59
GaryVoshol's Avatar
Cogito ergo arbitro
If the narrowest portion was 7-8", the widest portion could be more than 10" (the height of the slot).
It would have been larger than most tubes, but without measurement of the narrow section, we wouldn't know if it was out of spec.
(since 2004)
Unread 20-02-2011, 12:04
MarcD79's Avatar
AKA: Marc
As the rules state, the tube is measured at the smallest section & can be between 7-8 inches. We had the official "C" shaped template that slid over the tube as you inflate them. When the tube was inflated to make contact with the template, the inflation was completed. If the corners (triangle tube) appeared to be larger than the sides, that was considered acceptable.
Mentor & Volunteer
Unread 20-02-2011, 12:07
zebrabots zebrabots is offline
FRC #2909
zebrabots is on a distinguished road
So here is my question. From what you guys saw at the practice rounds, what would make a good defensive robot? Such as small and nimble to move fast or large and bulky to block arms and things? Or what other characteristics would you find on a great defensive robot?
Unread 20-02-2011, 12:23
ttldomination's Avatar
Sunny
I would think that a fast robot that can throw around its weight would be the most annoying. It's hard to play defense in this game, but it's possible to pester many robots so that it's harder to pick up tubes and even drive straight.
Also, a defensive robot that doesn't get penalized is key. There are very strict penalties for overaggressive defense.
1648: 2013-2014
5283: 2015
