Go to Post If you don't like getting tipped don't build a robot that tips. - Koko Ed [more]
Unread 20-02-2011, 00:16
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
pic: Tube Sizes can Vary A Lot!
Unread 20-02-2011, 00:20
alicen's Avatar
alicen alicen is offline
Zebra Committee
alicen is just really nicealicen is just really nicealicen is just really nicealicen is just really nicealicen is just really nice
Re: pic: Tube Sizes can Vary A Lot!
Having been around in 2007 for Rack 'n Roll, I remember that behind the scenes at CMP, there were these three-sided wooden "boxes" that the volunteers used for blowing up the tubes to ensure that the tubes were all as close to the same size as possible. I'm fairly certain that they will implement another simple way to accomplish uniform sizes for the tubes. They may not be able to do this at scrimmages, but it will more than likely happen at regionals and CMP
Peachtree Regional Volunteer since 2003
Unread 20-02-2011, 00:31
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
using the bottom blue square tube as a reference, assuming a side length of 25 inches as defined in the manual, the triangle has a side length of 41 inches (11 inches more than the manual says it should be) and a maximum thickness of 14.3 inches!
Unread 20-02-2011, 02:09
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Build a grabbing device that takes varying inflated tubes out of the equation.
Unread 20-02-2011, 02:25
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
In the real world nothing is ever to spec. Just another part of the challenge.
Unread 20-02-2011, 10:50
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Frankly I thought the tubes would burst at the inflation levels we saw in Suffield.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 20-02-2011, 11:01
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Using shop air to inflate tubes is not a problem, IF you know when to stop inflating!
I expect the regionals will have more evenly inflated tubes, but they still won't all be consistent, and if your manipulator can't deal with it, you might want to think of ways to modify your manipulator so it can deal with it.
Unread 20-02-2011, 11:31
MarcD79's Avatar
MarcD79 MarcD79 is offline
AKA: Marc
FRC #0176 (Aces High 176)
MarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond repute
Originally Posted by corpralchee View Post
Given the different shapes of the 3 tubes, I can see the discrepancies. BUt here is the official rule from FIRST
2.2.9 GAME PIECES
While playing LogoMotion, HOSTBOTS manipulate GAME PIECES to accomplish the objectives of
the game. Each GAME PIECE is an inflatable object constructed of 0.3 mm thick vinyl. The body of
each GAME PIECE has a tubular cross-section, nominally between 7 and 8 inches in diameter at
their narrowest. The GAME PIECES are inflated to nominal size, not a specific pressure.
As has been said. If your robot clamp is constructed to fit an exact size, it might not have the ability to clamp down properly. They need to have flexibility built in.
Mentor & Volunteer
Field setup, Field Supervisor & disassemble Suffield Shakedown 2003- present (2015)
Connecticut Regional Field setup, disassemble & FTAA 2009, 2010, 2011, 2012, 2013 (Field reset & Assistant Field Supervisor), Field Reset Pine Tree Regional 2013, Field Supervisor, setup & take-down at Groton & Southington Districts 2014, Field Reset Hartford District 2014. Field Reset Boston District Championship 2014. FLL Judge Fall 2014
Field Supervisor/Set-up & Take-down Waterbury & Springfield , Field Reset/Set-up & take-down Hartford N/E District 2015. Field Reset NE Champs 2015. FLL Judge Fall 2015.
Suffield Shakedown 2016, Field Super 2016 Stronghold Waterbury.
Unread 21-02-2011, 00:10
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
That has nothing to do with the problem of the human player not being able to feed it through the feeding slot.
Unread 21-02-2011, 06:18
waialua359's Avatar
AKA: Glenn
Read OP's last statement.
If it doesnt fit through the slot, throw it over and pick it up from the ground.
If you cant pick it up from the ground, read my statement again.
Unread 21-02-2011, 11:15
GCentola's Avatar
GCentola GCentola is offline
Strategical Tactitian
AKA: Garrick
no team (SparX)
GCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud of
As far as we found, there is no rule preventing the inflation/deflation of tubes by the human player. Ifa tube is hugely over inflated, couldn't the FEEDER deflate it slightly?
GO SparX on 3!!!!!
Check us out at:
http://www.gosparx.org
http://www.facebook.com/SparX1126
I Love Two Pencil Designs!
Unread 21-02-2011, 11:52
Dancin103 Dancin103 is offline
The Crazy Blonde
AKA: Cassie
FRC #0103 (Cybersonics)
Dancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond repute
Send a message via AIM to Dancin103
It's a good idea, and even if they could, would you really want your HP taking the time to stand there and deflate tubes? Like Ed said, just throw them over the top. It's a good thought, but I personally would not want my HP spending the time deflating the tubes when they could just toss them over the top.
Just my two cents.
Cybersonics Technology Team 103
2003 Championship Chairman's Award Winners
NEED CHAIRMAN'S HELP?? Subscribe to our YouTube Channel, we answer your questions daily!
Unread 21-02-2011, 13:35
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Glen, I agree with you since we can pick up from the floor.
But it has me thinking, what about all of the teams that designed to pickup directly from the Feeder Slot? This strategy is considered viable according to the manual, as tubes are allowed to be fed through the feeder slot. That being said, shouldn't someone ensure that the game can be played according to the rules? What is the point of the slot if the tubes don't fit through it? I hope that someone is keeping a close eye on tube inflation at our events.
-Dustin Benedict
Unread 21-02-2011, 13:57
Best Available Data
FRC #1778 (Chill Out!)
If a supplier cannot reliably meet their own specs, then they will go out of business. No one wants a supplier they can't rely on. Things may deviate -- but this should be part of the spec sheet.
Of course, people who design their manipulators for the specific diameter FIRST puts in the manual haven't been in FIRST for long enough.
