Go to Post FIRST is again mirroring real life. And in real life, when we build and design robotic and automated systems, it's safety first. Hitting a human in real life loses a lot more than 30 points. - Fred Agnir [more]
Unread 20-02-2011, 13:01
PranavSathy PranavSathy is offline
Team Captain
AKA: Pranav Sathyanarayanan
FRC #0263 (Sachem Aftershock)
PranavSathy is an unknown quantity at this point
Re: Programming Light Sensor
I just want to point out though that your signal return, a.k.a the DigitalInput->Get() on the sensor will vary depending on which wire you put for the digital input, the Black (light out), or White(dark out), the code above would work for the white wire, Dark out, which will return 1 if it is on the line, and 0 if it is not. Good luck!
