Go to Post I love it when awards go to the right people. - David Kelso [more]
Unread 20-02-2011, 13:38
Peragore's Avatar
Peragore Peragore is offline
CEO of Black Magic
AKA: Philip Mulford
FRC #3373 (Team Robohawk)
Peragore is an unknown quantity at this point
Problems Deploying Code
Hi there,
We are at the stage in which we are trying to deploy the code to our robot. We are running C++ in Windriver and our code works perfectly well when we run it. When we try to deploy the code, Windriver says we do deploy the code, but the deployment seems to stop with about 25% remaining. When we go to use the robot, we get a no robot code message. We using a Toshiba Satellite L675 with Windows 7 64-bit. We have gotten the Licproxy error and run that manually when building. Any help is appreciated.
while (life){
  frcObsession = true;
  obs.ProgramAndObsess();
if (!life) life = true;
Unread 20-02-2011, 14:36
Peragore's Avatar
CEO of Black Magic
AKA: Philip Mulford
Re: Problems Deploying Code
Any help? Our Problem is similar o the deployment problem experienced by Team 2606 found here.
while (life){
Unread 20-02-2011, 18:30
Peragore's Avatar
CEO of Black Magic
AKA: Philip Mulford
The problem was solved as detailed in this thread
while (life){
Unread 20-02-2011, 18:57
Peragore's Avatar
CEO of Black Magic
AKA: Philip Mulford
We have it working now, the fix is found here.
while (life){
