Go to Post Weren't you ever told Canada is backwards from the US? - Alex Cormier [more]
Unread 02-20-2011, 01:40 PM
Rosemount2606 Rosemount2606 is offline
FRC #2606
Rosemount2606 is an unknown quantity at this point
Re: .out file not building!
ok... we have found a solution, but uncovered more problems.
first, we build the project. It does not create the .out file.
To solve this, we then rebuild the project (actually using "rebuild") and it then correctly updates the .out file.
When we deploy the code, it appears as if it is being deployed properly. The transferring file bar goes all the way across. There are no errors at this point.
At this point, we reboot the robot. We have tried doing this both via the classmate rebooting the crio, and a manual reboot of the robot by resetting its power.
Then, we reestablish comms with the robot, only to see that the new code is not on the robot.
We have tried re-imaging the robot, and then repeating the above steps, all of them working fine. Now, instead of still having the same old code on the robot, we have no code on the robot. We are unable to get any code onto the robot.
We have tried deploying code from another computer as well, and it didn't solve the problem.
Before re-imaging the crio, we tried undeploying code from the robot, but it would not work.
We are using windriver.
