Robot Code not taken
Ok, so I am trying to load code to the cRIO and it goes through the deployment process and loads correctly, but the driver station says that there is not Robot Code. Please, I have already reimaged, checked the router, rebooted, and it still doesn't work.
Re: Robot Code not taken
The proper steps for code deployment are:
1. In the Project Explorer click the '+' next to "Build Specifications" under the "RT Compact RIO" menu. 2. Right click on "FRC Robot Boot-Up Deployment" and click "Build" 3. After the code finishes building right click on the same place again and click "Run as startup" 4. After the code is loaded Labview will pop up a dialog asking to reboot the cRIO. Allow it to reboot. Is that the process you were following? |
