Go to Post And Dave, although I know you have connections, please don't slow the earth's rotation to get more time on the caption contest. ;) - Billfred [more]
Unread 19-02-2011, 16:07
Nicandy's Avatar
Nicandy Nicandy is offline
AKA: Nicole/Andy
FRC #3580 (Marinerds)
Nicandy is an unknown quantity at this point
Axis Camera Help
After wiring up the axis camera (which worked fine when plugged into the wall), we found that, even though we were getting 5 volts from the PD board, and 5 volts from the part that connects to the camera, we just aren't recieving an image. Can anyone tell me what the problem might be? Thanks for your help.
Unread 19-02-2011, 20:34
Re: Axis Camera Help
When you say it worked when plugged into the wall, do you mean you could connect to it and get a picture using a web browser?
Did you reconfigure it to have the necessary user name and password?
What color is the ring around the camera lens?
What language are you using to program your robot?
Unread 20-02-2011, 13:16
Nicandy's Avatar
AKA: Nicole/Andy
Yes, not sure, gray, and Windriver.
I'm wasn't directly involved with the programming, so I'll have to ask about the username and password thing.
Also, we had originally started with LabVIEW, but we're in the process of refiguring our cRIO to work with Wind River.
Thanks for your response!
Unread 20-02-2011, 14:12
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
In your programming you have to start it with getInstance or use getImage for working with the picture.
Unread 20-02-2011, 17:23
Nicandy's Avatar
AKA: Nicole/Andy
Smile Re: Axis Camera Help
Oh... I didn't realize that we had to program it to get an image to show! Thanks!
