Go to Post Nobody has ever complained that someone was too willing to share their knowledge of building robots or their new ideas for anything. - Josh Hambright [more]
Unread 20-02-2011, 12:23
Mark_K Mark_K is offline
FRC #1721 (Charette)
Mark_K will become famous soon enoughMark_K will become famous soon enough
PID Example HELP
We're new to Java this year and we were having some problem with PID.
PIDController doesn't seem to work, and we were wondering if we could possibly have some code to use as guidelines that has PID in it.
Thanks
Unread 20-02-2011, 14:03
Re: PID Example HELP
We are unable to initialize it. We import the library and when tried to call the error says cannot find symbol. symbol: constructor PIDController()
Unread 20-02-2011, 14:08
ArchVince's Avatar
ArchVince ArchVince is offline
FRC #1290 (Si Se Puede)
ArchVince will become famous soon enough
Are you passing the required argument? Take a look at the documentation, and there are two constructors. Both require arguments.
PIDController(double Kp, double Ki, double Kd, PIDSource source, PIDOutput output, double period)
and
PIDController(double Kp, double Ki, double Kd, PIDSource source, PIDOutput output)
PETA wants your help finding Schrödinger.
Unread 20-02-2011, 14:18
Yes, the code is PIDController(pVal , iVal , dVal, armposition, arm);
armposition is from the pot and arm is the jag
Unread 20-02-2011, 14:24
ArchVince's Avatar
What type of objects are each one? I'm unclear on what pot is, my apologies.
That sentence did not come out like I meant it to.
Unread 20-02-2011, 14:26
double, double, double, edu.wpi.first.wpilibj.AnalogChannel, edu.wpi.first.wpilibj.Jaguar
Unread 20-02-2011, 14:34
ArchVince's Avatar
Is cannot find symbol. symbol: constructor PIDController() the exact error message? Because just as a test, I tried to initialize a Solenoid with a string as an argument and it said cannot find symbol. symbol: constructor Solenoid(java.lang.String). That would mean that it isn't being given any arguments whatsoever. Is there another place in your code where you accidentally initialized one, perhaps?
Unread 20-02-2011, 14:39
symbol: method PIDController() is the error
Unread 20-02-2011, 21:08
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
I believe the problem is your source and output. You are sending edu.wpi.first.wpilibj.AnalogChannel, edu.wpi.first.wpilibj.Jaguar, while PIDController expects classes implementing the edu.wpi.first.wpilibj.PIDSource and edu.wpi.first.wpilibj.PIDOutput interfaces. The idea is that you create your own classes implementing these interfaces, and pass them to the constructor.
My bad, I must have checked the wrong class in the javadoc somehow.
while(!going.isTough());
tough.exit();
What will we do tonight, Warfa?
The same thing we do every night, Patrick. Sit and wait for Electrical.
Unread 21-02-2011, 00:01
Geek 2.0 Geek 2.0 is offline
FRC #0107
Geek 2.0 will become famous soon enough
AnalogChannel implements PIDSource and Jaguar implements PIDOutput, so that's probably not their problem.
Unread 21-02-2011, 00:40
ArchVince's Avatar
Yeah, it should be able to work. I'm still curious about two things, though.
1. The error says it's a method, not a constructor.
2. The error doesn't list ANY arguments.
Any chance we could see the part of your code that is erroring?
