Go to Post All I can say is - we are such geeks! - Raul [more]
Unread 20-02-2011, 14:23
Rosemount2606 Rosemount2606 is offline
FRC #2606
Rosemount2606 is an unknown quantity at this point
Re: .out file not building!
Originally Posted by tomy View Post
are you changing something in the wpilib that is not changing when you download it to the robot or what is wrong
we are not changing it
Unread 20-02-2011, 14:24
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
so then what is the problem??????
Please read the entire thread...
Rosemount: Could you please post your source code? We have found WindRiver and vxWorks can do some odd things, sometimes an obscure runtime error will make the illusion of it uploading but older code is ran.
EDIT: You are doing Undeploy -> Deploy -> Reboot robot correct?
Unread 20-02-2011, 14:26
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
have you reimaged your crio?
have you updated windriver?
on the crio are all dongles off but counsel out?
have you done a clean build?
do you have anything in your code that is not hooked up to the robot?
ex: sensor, encoder....
Unread 20-02-2011, 14:28
FRC #2606
That is correct. The first time we do it, a window opens and closes immediately, so we cannot read it. If we do that again, is says "Unable to delete the UserProgram from the robot."
posting source in a second.
Unread 20-02-2011, 14:33
FRC #2606
In an attempt to fix our problems we have created a new project and widdled our code down to the essentials.
RJoystick is just a subclass of Joystick.
Our ZomBDashboard was working before we ran into these issues.
#include "WPILib.h"
#include "ZomBDashboard.h"
#include "RJoystick.h"
 * This is a demo program showing the use of the RobotBase class.
 * The SimpleRobot class is the base of a robot application that will automatically call your
 * Autonomous and OperatorControl methods at the right time as controlled by the switches on
 * the driver station or the field controls.
class RobotDemo : public SimpleRobot
	RobotDrive 		myRobot; // robot drive system
	RJoystick 		leftstick; // only joystick
	RJoystick	 	rightstick;
	ZomBDashboard 	zomb;
	Jaguar 			winch_motor;
	Compressor 		compressor;
public:
	RobotDemo(void):
		myRobot(1, 2),	// these must be initialized in the same order
		leftstick(1),		// as they are declared above.
		rightstick(2),
		zomb(ZomBDashboard::GetInstance(TCP)),
		winch_motor(3),
		compressor(5,4)
		myRobot.SetExpiration(0.1);
	 * Drive left & right motors for 2 seconds then stop
	void Autonomous(void)
		myRobot.SetSafetyEnabled(false);
		myRobot.Drive(0.1, 0.0); 	// drive forwards half speed
		Wait(2.0); 				//    for 2 seconds
		myRobot.Drive(0.0, 0.0); 	// stop robot
	 * Runs the motors with arcade steering.
	void OperatorControl(void)
		myRobot.SetSafetyEnabled(true);
		while (IsOperatorControl())
			compressor.Start();
			leftstick.UpdateButtonStates();
			rightstick.UpdateButtonStates();
			myRobot.TankDrive(leftstick, rightstick);
			if(zomb.CanSend())
				zomb.Add("leftStickAxis", leftstick.GetY());
				zomb.Add("rightStickAxis", rightstick.GetY());
				zomb.Add("testtext", "RWRRSARSR");
				zomb.Send();
			Wait(0.02);//Min time to wait is 0.005
START_ROBOT_CLASS(RobotDemo);
Unread 20-02-2011, 14:36
FRC #2606
-Im not really sure where to find a windriver update but i feel like ours should be updated.
-Yes we reimaged the CRIO, thats why we not have no code on or robot.
- Yes the dongles are off except console out
-Yes we did a clean build
-No
if i remember right you are missing a brace here
ZomBDashboard zomb;
Jaguar winch_motor;
Unread 20-02-2011, 14:38
FRC #2606
ZomBDashboard zomb;
Jaguar winch_motor;
negative ghostrider. If that were an issue, we would of gotten a compiler error.
Unread 20-02-2011, 14:46
FRC #2606
I'm not sure if this helps but we tried following this(Start on p.12) guide on Debugging the robot. The "Entry Point" of FRC_UserProgram.... it tells us to use is no where to be found.
Unread 20-02-2011, 14:47
Peragore's Avatar
Peragore Peragore is offline
CEO of Black Magic
AKA: Philip Mulford
FRC #3373 (Team Robohawk)
Peragore is an unknown quantity at this point
we are having the same problem with deploying our code. We have tried everything mentioned in this thread and nothing has worked. Im with team 2606 on this one. And its bizarre because it worked perfectly at the beginning of the build season for us.
while (life){
  frcObsession = true;
  obs.ProgramAndObsess();
if (!life) life = true;
Unread 20-02-2011, 15:05
FRC #2606
If it helps, we are deploying it, so to speak. It just seemed like this may have been overlooked. It says it is deploying properly, but when we reboot the robot, it has no code on it.
Unread 20-02-2011, 15:08
Peragore's Avatar
CEO of Black Magic
AKA: Philip Mulford
That's is what is happening to me as well. Its like the code vanishes as it goes from the laptop to the cRIO
while (life){
Unread 20-02-2011, 15:21
check the dongles on the crio
this happened to us in our first year.
all of them should be off exept for counsel out
also how are you rebooting ?
Unread 20-02-2011, 15:28
FRC #2606
We are rebooting through the driverstation and cutting power via the breaker, and then giving it back to the robot
Unread 20-02-2011, 15:42
all you have to do to reboot is use the driverstation
make sure the code fully downloads
are you using the clam for programming?
