Go to Post This 6 weeks of work, sweat, thinking, designing, building, talking, discussing, turning wrenches, wiring, programming, drawing on chalk boards, eating pizza, drinking mountain dew, with the students - is what the FIRST experience is really about. - meaubry [more]
  #31   Spotlight this post!
Unread 20-02-2011, 15:42
Peragore's Avatar
Peragore Peragore is offline
CEO of Black Magic
AKA: Philip Mulford
FRC #3373 (Team Robohawk)
Peragore is an unknown quantity at this point
Re: .out file not building!
Originally Posted by tomy View Post
check the dongles on the crio
this happened to us in our first year.
all of them should be off exept for counsel out
also how are you rebooting ?
Thanks! Flipping the console out switch on fixed it for us.
while (life){
  frcObsession = true;
  obs.ProgramAndObsess();
if (!life) life = true;
  #32   Spotlight this post!
Unread 20-02-2011, 15:46
Rosemount2606 Rosemount2606 is offline
FRC #2606
Rosemount2606 is an unknown quantity at this point
all you have to do to reboot is use the driverstation
make sure the code fully downloads
are you using the clam for programming?
I meant to say that we have tried both methods, mainly we have just been doing the reboot of the crio via the classmate, but since that wasn't working, we also tried the physical reset.
The code has "fully downloaded". As in, when we say to deploy, the transfer status bar fills up.
We do not know what you mean by "the clam for programming"
thanks for the help!
  #33   Spotlight this post!
Unread 20-02-2011, 15:54
garyk garyk is offline
Programming Mentor: 668, 972, 2643
FRC #0668 (Apes of Wrath)
garyk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the rough
Originally Posted by Peragore View Post
we are having the same problem with deploying our code. We have tried everything mentioned in this thread and nothing has worked. Im with team 2606 on this one. And its bizarre because it worked perfectly at the beginning of the build season for us.
OK, I'm going to suggest some things you may (or some other team) has tried already:
WindRiver => Project => Clean. Click "Clean all Projects" and turn "Start A build Immediately" OFF, OK. Clean deletes the .out file and other temp files that the compile and link process creates.
WRW => Project => Close for all open projects.
With the robot on, etc: WindRiver => Deploy. It should fail because the .out file was removed by the clean but shouldn't complain about not connecting to the 'bot. Hit Details and check.
Exit WRW and reboot your PC and the Drivers Station. Power cycle the robot.
WRW => File => New => Example => VxWorks downloadable kernel module sample proj. Choose "FRC Drivers Station LCD Text" (I assume you haven't created this proj already). The project will be created and opened.
WRW => Project => Build Project. There should be no errors or warnings.
WRW => Window => Preferences => FIRST downloader Preferences. Your team number should be correct. Browse and select the .out file you just built. It should be (maybe broken into two lines or have a space here):
C:\WindRiver\workspace\DriverStationLCDText\PPC603 gnu\DriverStationLCDText\Debug\DriverStationLCDTex t.out
Don't hit OK yet. In the Browse window upper right frame are the icons: green arrow up, new folder, and the rectangle with the six dots. Click the rectangle and select Detals. Verify that the Modify timestamp on your .out matches the date and time you just did the Build Project above. Click on that .out, Open, OK.
Make sure the 'bot is on and wireless is up.
WRW => FIRST => Deploy. The file should download to the 'bot.
Power cycle the 'bot, bring up the Drivers Station if you haven't already, and get connected.
Enable the robot and the text "Hello World" and the time should appear on the Drivers Stn LCD. I HAVE NOT RUN THIS PROGRAM and I can't get to our 'bot now. I'm going to assume the program is written correctly.
Let us know what happens. If it just doesn't work it's probably time to uninstall WRW and reinstall it, including the patches.
Silicon Valley Regional 2005, 2006 972
Silicon Valley Regional 2007 668 Xerox Creativity Award
Championship Event 2007 668
Portland Regional 2008 668
Silicon Valley Regional 2008 668, 972
Beta Test Team 2008 668 (with 100 & 254)
Silicon Valley Regional 2009 668 Regional Chairman's Award; 2643
Sacramento Regional 2009 668 Winning Alliance (thanks, 1717 & 2473!), 2010 Winning Alliance 3256
CalGames 2006, 2007, 2008, 2009, 2010, 2011 Field Tech
NorCal FTC Regional 2008, 2009 Inspector
Championship Event 2009
San Diego, Silicon Valley Regionals; Champ. Event 2010 668, 2643, 3256
Silicon Valley, Madera Regional 2012 2643
WRRF Programming Instructor 2006-2016
Regional Woodie Flowers Award 2014 2643 Utah Regional
  #34   Spotlight this post!
Unread 20-02-2011, 16:18
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
WindRiver frequently says stuff that is incorrect . Sometimes the progress bar will complete even when there is no connected target >_>
I...think...he means the netbook provided in the kit of parts (reference to Clamshell netbooks?).
  #35   Spotlight this post!
FRC #2606
Random Information: After cleaning the project and trying to deploy, got a "IO Error while downloading program to robot"
After creating the DriverstationLCD project. I told it to build and it did not create a .out file. I restarted windriver and the rightclicked the projected and said "Rebuild." This created the .out file.
Everything went according to your directions.
Excellent. The text is up on the driverstation. Thank you.
I will now try to put our code on the robot and post after.
  #36   Spotlight this post!
Unread 20-02-2011, 16:19
Emily Horsman
-Im not really sure where to find a windriver update but i feel like ours should be updated.
I mean this in the most gentle way possible: This isn't satisfactory.
http://firstforge.wpi.edu/sf/frs/do/...e_for_2011_f_1
  #37   Spotlight this post!
Unread 20-02-2011, 18:26
Peragore's Avatar
CEO of Black Magic
AKA: Philip Mulford
Thanks for the help, but we already managed to fix this. When we flipped the console dongle to "On" we were able to deploy. I hope this as well as what you wrote, can help other teams!
while (life){
