Go to Post Guys, Can we agree that "we used it in the past" is not a response. Thanks. - Al Skierkiewicz [more]
Unread 20-02-2011, 14:47
sonicwingmode sonicwingmode is offline
FRC #3404
sonicwingmode is an unknown quantity at this point
Re: how to program mecanum wheel drive?
so, how do I program this?
Unread 20-02-2011, 14:56
Just like any other motor: it depends on what you want to do with it.
Unread 20-02-2011, 15:22
FRC #3404
ok, thanks
Unread 20-02-2011, 17:02
FRC #3404
our team is trying to use the relay to control the window motor, how do we program this?
Unread 20-02-2011, 17:09
http://www.chiefdelphi.com/forums/sh...09#post1025209
Unread 20-02-2011, 17:10
FRC #3404
edit: where do we put the program in?
Unread 20-02-2011, 17:18
FRC #3404
the help here is awesome!
Unread 20-02-2011, 17:25
FRC #3404
where do we find "Button 1"
Unread 20-02-2011, 17:29
On the Attack3 Joystick it would be the trigger.
Unread 20-02-2011, 17:34
FRC #3404
ok, I've found it.
Now where do I put this new program under? (begin? teleop? robot main?)
Unread 20-02-2011, 17:42
FRC #3404
http://www.chiefdelphi.com/forums/at...8&d=1265156994
we use this program for the relay control and we put it under "robot main" and it doesn't seem to work
year 2 and still noobs in labview, lol
Unread 21-02-2011, 00:13
Everything you want to happen during teleoperated mode goes in the Teleop vi.
All of the "Open" functions should be done once as initialization, and they go in the Begin vi. The associated "Close" functions go in the Finish vi.
