Go to Post The function of that part is to keep one student occupied playing with it during the entire build season. It doesn't have to be the same student all the time, they can take turns. - MrForbes [more]
Unread 20-02-2011, 12:43
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Wheel base and Pneumatic tires
This year, we decided to go with some COTS pneumatic wheels to give us an extreme amount of traction. However, we are having some difficulty with turning (as you might guess). I believe the design of the robot is solid, we are just missing something in the execution. In low gear (about 3.5ft/sec) the robot turns perfectly. In high gear (about 13.5 ft/sec) the robot turns decently, occasionaly it trips a breaker, most high gear turns need to be made as part of a fluid motion with driving forwards.
Here is what we have:
8 wheel drive with these: http://www.grainger.com/Grainger/ERW...PE1?Pid=search
The two (per side) center wheels are dropped 1/4 inch
The turning base is 24 inches wide from center to center of the wheels, and it is 13.5 inches in length from center to center.
For those that have experience with pneumatic wheels, I am looking to what types of modifications will increase handling. Right now, all i can think of is switching out wheels and air pressure. On the air pressure note: I am having a hard time finding a pump with a gauge that will read in the 20-35psi range.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 20-02-2011, 13:19
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
Re: Wheel base and Pneumatic tires
You could try programming an automatic transmission that drops into low as soon as you get to those low speed turns. Other than that, an air pressure increase seems like it would help. I can tell you right now though, we have had a fantastic traction experience with the roughtop plaction wheels from AndyMark, and they are a lot more predictable.
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 20-02-2011, 13:21
You may want to put lower-traction wheels on one or both ends. That helped a 6WD deal with turning issues.
Unread 20-02-2011, 13:41
Chris is me's Avatar
AKA: Pinecone
Inflate the center wheels more - make sure they are as much as possible so they don't compress too much.
a 6WD might have turning issues, but a properly inflated 8wd shouldn't.
Unread 20-02-2011, 18:36
WileyB-J's Avatar
WileyB-J WileyB-J is offline
4976 Georgetown Rebels
FRC #4976 (Rebels)
WileyB-J will become famous soon enoughWileyB-J will become famous soon enough
higher end bicycle pumps will give you an accurate reading in the 20-35psi range (I used to be a bike tech) make sure you get one with a schrader valve (car tire style) as many road bike specific ones are presta valve only (the long skinny one with the screw top).
maybe lower psi on the middle wheels and raise the psi on the outer wheels? (also lower the middle wheel axle a bit more)
lowering psi allows more surface contact thus traction. no offense to the other suggestions but increasing the psi in the middle will do you little good (except lowering the center wheel, but its much more practical to adjust the fixed axle position)
Unread 21-02-2011, 13:25
You may find the following whitepapers helpful. http://www.chiefdelphi.com/media/papers/1443 http://www.chiefdelphi.com/media/papers/1917
Unread 21-02-2011, 14:12
Jeffy's Avatar
Retired, for now
AKA: Jeff Gier
Thank you very much everyone, it was air pressure. Works great now that we have some more pressure in the tires.
2010 GKC Finalists
2010 OKC Champions
2012 CO Finalists
Unread 21-02-2011, 18:33
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Our bot was back side heavy with the 6 wheel configuration (it worked fine on concrete, but carpet was a killer). We could not turn during the scrimmage. So we replaced the back wheels with the smooth plastic ones, it was a thing of beauty.
