Go to Post "The compressor is half the temperature of a toasted Subway sandwich." - Ashley Hartley [more]
Unread 20-02-2011, 18:38
Chris is me's Avatar
AKA: Pinecone
pic: 2791 Starting Configuration
Unread 20-02-2011, 18:40
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: pic: 2791 Starting Configuration
That's a really neat idea!
Unread 20-02-2011, 19:54
AKA: Pinecone
No idea where that came from, nope...
We stepped up the PVC tube diameter for a bit more rigidity than your system. It's paid off pretty well! Now that I think about it, our robots are dramatically similar this year...
Unread 20-02-2011, 20:26
Joining the 900 Meme Team
FRC #0079
How do you hold an ubertube for auton?
Unread 20-02-2011, 20:30
MrForbes's Avatar
AKA: Jim
I expect they'll have to pick it up off the floor. Probably requires a bit of forward/backward driving to get it.
Unread 20-02-2011, 20:36
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Did you guys have something really cool in your base or was that guy just admiring your work?
Anyway, the bot looks awesome - get those guys some practice and it'll do great.
-Dustin Benedict
Unread 20-02-2011, 20:37
AKA: Pinecone
Unfortunately, the gripper open breaks starting configuration, so our plan is to floor load. It probably will take more time to tune than we have to make it work (we have a Thursday) but oh well.
We've got a removable electronics board and cantilevered drive. They look cool!
We don't have much time for practice, but luckily we have a veteran driver waiting to get his hands on the bot.
Unread 20-02-2011, 20:40
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Chris,
Great robot, did you guys not have weight for an aluminum arm?
-RC
R.C.
MadTown Robotics Team 1323
Unread 20-02-2011, 20:42
AKA: Pinecone
Originally Posted by R.C. View Post
Chris,
-RC
We're well under. PVC was cheaper, more available, and could more easily slide within each other without the need for any actuation. It's also easier to work with.
We bought very large (2.5" outer stage) PVC to ensure there'd be some rigidity in the arm.
Unread 20-02-2011, 20:45
MrForbes's Avatar
AKA: Jim
We have enough rigidity with a 2" outer arm and 1.5" inner. It wiggles, but that's not a problem. Using ABS lets us have less weight and a more robust arm, but as you noticed the only 2.5" you can find easily is gray electrical conduit.
Unread 20-02-2011, 20:49
FRC #0079
Perhaps look into a single shot piece that holds the tube to you and your arm grabs from at the start of match. 27 did something like that in 2005 and it worked pretty well. The last thing you want is to introduce MORE human error into your auton.
Unread 20-02-2011, 20:55
AKA: Pinecone
There really isn't a good place to put something like that. The arm has a very limited range of travel so it can't bend around a corner to grab something weirdly placed.
Current plan is to put tube on ground touching bumper. Back up, extend arm, open gripper, drive into tube, close gripper, proceed with auton.
MrForbes's Avatar
AKA: Jim
might want to add "push tube forward" in there somewhere
Unread 21-02-2011, 11:17
That's what we did in 2007. I think we missed only once in about 50 matches.
Unread 21-02-2011, 11:34
KleinKid KleinKid is offline
FRC #3735
KleinKid is a jewel in the roughKleinKid is a jewel in the roughKleinKid is a jewel in the rough
Team 3735 is earliy similar to this but our system is a little more sturdy i think. We used 1" aluminum inside of 1.5" aluminum and instead of gravity for extension we rigged up a 1.5" bore pneumatic piston. Being able to retract the arm during the game makes driving around and placing tubes on the rack much easier.
I'm very jealous and curious of your 7 victor controlers on your electronics board. 4 are probably for the CIM motors on your drivetrain but what are the other three used for other than controling the arm?
