Go to Post Calling the refs "zebras" is just fine. Just don't call 'em late for dinner (or visually impaired). - EricH [more]
Unread 20-02-2011, 17:04
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
D-Link Randomly Dropped Wireless Link
We have had an ongoing problem with the wireless link going down randomly. It would eventually recover without power cycling anything. It appears to be isolated to be the Dlink as the C-Rio would still be running and had not rebooted. So we swapped to last years Linksys bridge and did not get a single drop of the wireless link with an hour of testing when we had one every 3-5 minutes before.
Power and cabling to the Dlink appears solid and reliable physically and the robot was being very lightly used (no collisions etc). We did not see the Dlink reboot but might have missed it.
Anyone else with similar experiences ? Its near the CPU and sidecar and the converter is right under it. Could EMI be affecting it (but not the Linksys in the same location) ?
Unread 20-02-2011, 17:29
aaronhammond11 aaronhammond11 is offline
FRC #0811
aaronhammond11 is an unknown quantity at this point
Re: D-Link Randomly Dropped Wireless Link
Have you updated the cRIO to the latest image file (v28)? We are having the same problem after updating our cRIO during a pre-regional event yesterday. It's quite infuriating, especially given the proximity to ship and the inability to test robot functionality.
Unread 20-02-2011, 17:30
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
when we hit the wall our dlink drops the wireless
also make sure you have a patch cable from your dlink to your crio
Unread 20-02-2011, 19:28
de_ de_ is offline
AKA: Dave Edwards
I believe we updated to latest version yesterday night (before testing today) but I also sort of remember losing the link before the upgrade.
Is there something special about the ethernet cable that came with the DLink versus any other cable. We had substituted a short 1' cable.
re dropping link when hitting wall: Ouch. We will have to see how things work in the early regionals. Could be a lot of dead robots.
Unread 20-02-2011, 20:00
There is nothing special about the cable, though perhaps you should see if the link lights are on or swap out to a different cable to see if that changes things.
Greg McKaskle
Unread 20-02-2011, 21:00
mtndurbin mtndurbin is offline
Programming Mentor
mtndurbin is an unknown quantity at this point
Exclamation Re: D-Link Randomly Dropped Wireless Link
It appears that this dropped connection is not random or a loose connection.
Our triage of this indicates that under heavy current draw, like when the
drive motors are running, the 12v power can drop to around 7 volts.
This low voltage condition causes temporary failure of the power converter
supplying power to the dlink. This results in the dlink performing a power on reset.
If you can safely, watch blue lights on the dlink while you drive the robot.
At the point of failure all of the DLINK blue indicators will blink simultaneously.
This will indicate a power on reset has occurred.
What I am now waiting for is the official fix for this.
Unread 20-02-2011, 21:12
Congrats on the troubleshooting.
Greg McKaskle
Unread 20-02-2011, 21:24
What is your wiring like? It sounds like you wired directly to the PDB through a breaker. You should have wired it to the dedicated 12v radio output on the PDB. This will output 12v until the battery gets to 3.5v or so.
Unread 20-02-2011, 23:00
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Is this allowed? Team 1296 had the same problem described here and we changed to using the 12V of the PDB but were not sure it is allowed.
Unread 20-02-2011, 23:08
Originally Posted by wireties View Post
Is this allowed?
It is actually required.
Unread 21-02-2011, 08:45
Programming Mentor
Thx I wiil verify with our electical department
Unread 23-02-2011, 16:05
Blackphantom91's Avatar
Blackphantom91 Blackphantom91 is offline
Mentor + 4 = Stuck For Life
AKA: Malcolm Stirckland
FRC #1986 (Team Titanium)
Blackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura about
Its new for this year so it gives the Dlink the right voltage. Other things that have been happening is the power cable is lose and it needs to be secure during play because you will get hit and it could knock it lose. Make sure the cables are not bad and the port on the router is still ok. (very easy to destroy the inside of that port and its connections). just some percautions that we have recently taken. Best of luck.
[img*]http://i.imgur.com/Os2oTET.jpg[/img*]
