Go to Post Corrected, math isn't my strong point (I went to art school for a reason) - KelliV [more]
Unread 20-02-2011, 17:08
AC Circuit Quiz #1
Suppose you have an air-core coil with inductance 200uH and resistance 0.09 ohms, connected in series with a 10 ohm resistor.
You apply a 15KHz 12 volt peak-to-peak sine wave across this series circuit.
What is the power dissipated in the coil?
What is the rms voltage measured across the coil?
Unread 20-02-2011, 17:14
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Re: AC Circuit Quiz #1
Are mentors elligible for the challenge?
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 20-02-2011, 17:19
Sure. Interested students can learn by studying your answer.
Unread 20-02-2011, 17:53
Manoel's Avatar
Let's work exclusively with rms quantities: 12 Volts peak-to-peak is 6 Volts amplitude, and dividing by the square root of 2 (~ 1.41), we get an rms voltage of 4.24 V from the source.
At 15 kHz, the coil's reactance is given by:
XL = omega*L = 2*pi*f*L = 2*pi*15*10^3*200*10^-6 = 18.85 ohms
The coil's impedance, then
Zcoil = 0.09 + j*18.85
The circuit total impedance, considering the 10 ohm series resistor:
Ztotal = 10.09 + j*18.85
We can now determine the circuit's total current, in magnitude:
|I| = |V|/|Z| = |4.24|/|10.09+j*18.85| = 4.24/21.38 = 0.198 A
The power dissipated in the coil, then, is due to its small resistance:
P = i^2 * R = 0.198^2 * 0.09 = 0.0035 = 3.5 mW
We can determine the voltage drop in the coil using a voltage divider:
Vcoil = Vsource * Zcoil/Ztotal = 4.24*(0.09+j*18.85)/(10.09+j*18.85)
Vcoil = 3.3062+j*1.7495
The rms voltage that you would measure with a voltmeter is the magnitude of Vcoil:
|Vcoil| = |3.3062+j*1.7495|
|Vcoil| = 3.74 V
Brazilian Machine
Team # 383
Last edited by Manoel : 20-02-2011 at 19:23. Reason: small typo... kilo = 10^3, not 10^-3
Unread 20-02-2011, 18:03
Nicely presented.
Students interested in AC circuit theory should carefully study your answer and ask questions if they need help understanding.
Unread 20-02-2011, 18:51
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
XL = omega*L = 2*pi*f*L = 2*pi*15*10^-3*200*10^-6 = 18.85 ohms
I believe you meant 2*pi*15*10^3.... not 10^-3. The math checks out otherwise.
Or am I just tired?
Matt
Matt Krass
Unread 20-02-2011, 19:21
Manoel's Avatar
Or am I just tired?
Matt
Yes, absolutely! The calculations are correct, I just typed it out wrong.
Brazilian Machine
Team # 383
Unread 20-02-2011, 19:34
Matt Krass's Avatar
AKA: Dark Ages
Yep, I did the math out before I said anything, I get the same impedance as you, just a minor typo.
This was a fun challenge, any particular reason for it? It almost sounds like a motor controller to motor, if the wave was square instead of sine.
Matt Krass
Unread 20-02-2011, 20:04
Just to raise awareness among interested students here on CD how AC calculations differ from the simple V=IR DC stuff they learned, and maybe motivate some to get into studying it.
Yeah, it was inspired by some recent discussions here involving motor inductance and how that affects power calculations.
Unread 20-02-2011, 20:14
Matt Krass's Avatar
AKA: Dark Ages
AC power stuff is almost a form of black magic.
Seriously though, it is pretty interesting, especially once you get in to reactance, systems can do weird things. I find students tend to get very interested in inductive backlash (which is what I call the tendency of inductive loads to cause interesting voltage fluctuations in an attempt to maintain current flow)
Matt Krass
Unread 21-02-2011, 02:50
JDL JDL is offline
Systems Integrator
FRC #0498
JDL is just really niceJDL is just really niceJDL is just really niceJDL is just really nice
Eww math. I did too much of that today already, load calculations and voltage drops, motor conductor sizing, I slacked off on some bids and paperwork this week
Students, while math is boring and you find it stupid (not that I blame you, no one really gives a darn where X is, it's more fun when you can apply it and make money off it) it is important if you want a technical career.
