Go to Post That tetra has personality! - Kevin Thorp [more]
Unread 20-02-2011, 10:17
Kevin Kolodziej's Avatar
Kevin Kolodziej Kevin Kolodziej is offline
Operator in 100+ matches
AKA: Yngwie Kamen's roadie
Kevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond repute
Send a message via AIM to Kevin Kolodziej
pic: 1675 - 2011
Unread 20-02-2011, 10:18
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
Re: pic: 1675 - 2011
Will you be covering up those precious electronics?
Every day is a new adventure!!!
Unread 20-02-2011, 10:27
Basel A's Avatar
Basel A Basel A is online now
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Make sure your arm either physically cannot hit your electronics, or put on a reliable cover!
Looks good though. It looks like that front roller articulates?
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 20-02-2011, 11:16
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Trust me, I was freakin' out about their setup with the electronics too, but it's currently not possible for it to touch the electronics as well as extra shields are going into place.
EDIT: Actual conversation yesterday:
Me: "Ah, i see there should be a couple inches at the very bottom between it and the cRIO."
Mechanical: "Inches?"
Unread 20-02-2011, 20:45
Mark Holschuh's Avatar
Mark Holschuh Mark Holschuh is offline
FRC #2194 (Fondy Fire)
Mark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud of
You team is almost done?! I was looking forward to a repeat of last year when you shipped an almost bare frame, and had the robot completely built and inspected by 8:00 on Thursday.
Unread 22-02-2011, 08:00
Now for some real video:
http://www.youtube.com/watch?v=2r7wwdsRFm4
Here are the facts:
- 8" Mecanum drive directly driven off of AM Toughbox Nanos geared at 12.75:1
- Custom 2x1 tube chassis
- Three stage (two cascading stages) elevator lift using teflon pads at contact points
- Winch powered by single FP with standard gearbox driving a 2" drum
- FP Victor is set to "motor brake" mode for a slow drift for scoring
- Elbow joint is balanced with surgical tubing and powered by a single window motor
- Roller claw has a hinged upper arm held tight with surgical tubing
- Rollers are driven by independent BaneBot 550s running 1:144 gearboxes (this will be changed to 1:132 in Milwaukee if the new gearboxes ever arrive)
- Total weight as shown (minus bumpers and battery) is 106.0
- Minibot works but will be improved; deployment still being worked on
Mark, we can't believe it either =)
The electronics have taken some abuse the last couple of days, but additional measures have been taken to prevent this from happening again.
Team 71: 1999, 2000 (Driver), 2001-2002 (Driver, Animator) // Team 1064: 2003 (Co-founder, Coach), 2004 (Coach) // Team 1714: 2006-2007 (Mentor, Coach)
Team 1675: 2005-2007 (Mentor, Coach), 2008 (Mentor), 2009-2017 (Mentor, Coach)
FLL: '04 (Judge), '05 (Ref), '06 (Ref), '07 (Ref), '08 (Judge, Ref), '09 (Judge), '10 (Ref), '16 (Judge Advisor) // Ref: '05 (IN, IRI), '06 (IN, IRI), '07 (IN, IRI), '08 (WMR, Curie)
WI RPC: 2006 - 2016 // FRC Inspector: '07 (WI), '08 (WI, IL), '09 (WI, IL), '10 (WI, CMP), '11 (WI, IL, CMP), '12 (WI), '13 (Northern Lights)
2007 WI Woodie Flowers Award Finalist // 2011 Wisconsin Regional Outstanding Volunteer // 2011/2013 Midwest Regional Chairman's Award
